Oil Breather Kits - Road Glide Forums
Old 11-14-2012, 08:06 AM
bikerglasses's Avatar
bikerglasses bikerglasses is online now
Default Oil Breather Kits
Anyone installing these on their bikes? Reading how the dirty hot oily air being directed to air filter sounds nasty.
haha
Sent from my SCH-I535
Ian -- Tucson, Arizona
2013 Street Glide - Denim Black - ABS/Security w/ Cruise
Old 11-14-2012, 03:37 PM
RoadGlideRider's Avatar
haha
The oil breather is still sent into the "Intake" of the motor.
Look at the rubber ducts in your A/C next time you have it off.
Old 11-14-2012, 08:38 PM
Exxon Valdez's Avatar
Exxon Valdez Exxon Valdez is offline
I couldn't find an aftermarket one for our bikes, so I made my own. The nasty oil collects in a catch can setup now, I have to drain it around 2500 miles. The catch can is an air / water seperator for an air compressor line that I bought at Home Depot.
'09 FLTR Black Pearl, ABS, Security, Stage 1 96", SE204s, SEPST, SE Intake, 2-1 SuperTrapp Supermegs, 13" MadStad, Heritage Bars, HD Vented Lowers.
Old 11-15-2012, 06:03 AM
killintime's Avatar
killintime killintime is online now
I'd love to see pictures of your setup
First prize is a Cadillac Eldorado. Second prize is a set of steak knives
Old 11-15-2012, 06:43 AM
Ok, I'll try to post some pics later today. In the meantime, if you do a search on here for "crankcase breather setup" you should be able to find another thread on here with a couple of older pics of how I rigged it up.
Old 11-15-2012, 07:27 AM
killintime's Avatar
Cool, thanks brother
Old 11-15-2012, 12:36 PM
Here are a few pics. The first pic was my first attempt on a silver SE backing plate. I just blocked off the small breather holes with black silicone. Then drilled and tapped a hole in each side of the backing plate for a 3/8 barbed fitting, where the breather bolts go. Then run some 3/8 fuel line to a T-connection then to an elbow and run that to the catch can. The oily crankcase air breathes through the catch can and out the other side. All the oily crap stays in the catch can and the rest of the air just breathes to the outside air. Tree huggers be damned.
Old 11-15-2012, 12:40 PM
I usually empty the catch can every oil change at 2500 miles.
Old 11-15-2012, 12:45 PM
Heres what its looks like. Keeps the bike clean and will help it run better overall. I've been running this for two seasons now with no issues. I like to run the proper amount of oil in the bike, instead of running it half full of oil to keep it from puking out on the motor.
Old 11-15-2012, 01:50 PM
killintime's Avatar
Nice, I think a trip to Home Depot may be in order.
