11-14-2012, 09:48 PM
Turn signals
Need help I'm new to this forum hopefully someone can help. I have removed my turn signals on my 2011 RG front and rear to get them powder coated but can't seem to figure out how to remove the internals meaning the reflector and wiring please help!
11-14-2012, 11:05 PM
The reflector just presses in. Get something small with a little hook type end on it and gentle pry it up through the small hole in it. You can then take the plug apart or cut and later splice the wires. Word of caution though. Not much wire to work with or room to tuck away spliced wires. I took the plugs apart and pulled the wires through......... Not sure any of that made sense after I read it. Good Luck though.
Life is Good
11-14-2012, 11:09 PM
^stole the words outta my mouth^
I did the exact same thing as HogWild when I did mine
11-15-2012, 03:46 AM
+2
It's just a press fit and held into place with the rubber boot/ring. Anything with a hook will work to pull them apart. I used a small L-shaped screwdriver.
On the wiring, the front connectors are pretty easy to disassemble - just release the tabs and the pins will come out. Rears are a little more challenging - the two bulb wires can be removed from the bulb base connector but I couldn't see how to disconnect the ground so I ended up cutting and splicing (adding an extension). As HogWild said, not much room to work with so a mistake here would prob require buying a new harness. It all worked out tho. Here's a few pics for you.
-phil
2011 FLTRX 103
11-15-2012, 06:56 AM
Thanks HD_Shock, I learned a little something from the pics.
 2010 FLTRX, Rev Performance 107, S&S 570G cams, Head work, Crank trued and welded, timken conv, CM 21" Titan, TMax, Dragos Dragula, Top Shop bags and fender, Holeshot LED's, Carlini Bag Drag bars, too many more things to list, and suject to change.
11-19-2012, 08:33 PM
Thanks guys for the help I was able to do the fronts with ease but as for the rear I just clipped the wire I will solder them back together when it comes back from the powdercoater
11-19-2012, 09:00 PM
Just remember if you take the connecter apart to mark which wire came out of which hole. Draw yourself a pic or actually take a pic to male it easier when its time to put it back together
11-21-2012, 04:18 PM
Yea I did that actually I went by the small numbers on the plug
