23 wheel - Road Glide Forums
Old 11-15-2012, 04:40 PM
RIPPINGWILD RIPPINGWILD is offline
Default 23 wheel
if you have 23 inch front wheel and have lowered your bike low can you let me know what you did to achieve this set up .
Old 11-15-2012, 04:44 PM
Colin1966's Avatar
Colin1966 Colin1966 is offline
check this out.
will be more help for ya.
http://choppedbaggers.com/forums/forum.php
Colin
Feb 14/1994-Nov 29 2012
Rest in Peace sweetheart.
Old 11-15-2012, 05:16 PM
GoneBlack's Avatar
GoneBlack GoneBlack is online now
With the front end raked (via a set of trees) it pushes the front axle center line forward, moving the wheel and fender with it.
How much did you lower your bike, depending on what your doing/plans are its not always the thing to do
Not to rep another site!!! But +2 on those guys knowing exactly what you'll need to do......most use trike trees for 23"
2012 Road Glide Custom....The build: http://www.roadglide.org/showthread.php?t=19311
CA spring Ride, book your room http://www.roadglide.org/showthread.php?t=26443
Old 11-15-2012, 05:58 PM
HogPro HogPro is offline
You have several choices when it comes to putting a 23" front wheel on your bike. The way that we did our shop bagger is without raking the bike, a progressive spring lowering kit, and an extra fork stop chopped in hal with half on each fork along with heavy fork oil. We used a 23" wrapped fender and that is it.
