Oil Bud Cooling - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Road Glide Equipment
Road Glide Equipment Post Equipment Resources Here
Old 10-20-2012, 08:35 AM
jacknife's Avatar
jacknife jacknife is offline
Default Oil Bud Cooling
Well I have done a search with no results. Just curious if anyone here is using one of these oil coolers or if anyone has tried one & didn't like it?
Very pricey, but if they work as well as claimed it maybe a good investment.
http://harleyoilcoolers.com/
Any advise or thoughts.
2013 Road Glide Ultra Midnight Pearl
Old 10-20-2012, 08:55 AM
staush's Avatar
staush staush is offline
Yours doesn't have one already?
2011 Road- Glide Custom-stock engine w/K&N air filter. I like it quite.
Old 10-20-2012, 09:08 AM
jacknife's Avatar
Yes it has the small factory oil cooler, just looking for something better. I do alot of mountian riding usually two up with the wife, looking around at slower speeds eliminating alot of air flow. I am around 285-295 & with her & crap in the bags the bike is packing a load Lol.
Old 11-05-2012, 08:20 AM
FLTR2008Trike's Avatar
FLTR2008Trike FLTR2008Trike is offline
I have one on my 117" triked Roadglide. The Oil Bud cooler works!!! It is as tough as they claim and will reduce your engine temps. I recommend it to anyone who wants a tough oil cooler that does cool your engine oil temps
Overcoming Adversity is the path to better ideas!!
S&S 124" Sleeper kit -10.9cc pistons. Torque Inc head porting and custom designed cams. 10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
Old 11-05-2012, 12:47 PM
Thistlethunder Thistlethunder is offline
I put one on my 04 bagger with a built 107" and it worked as advertised . Well built,easy to install and really made well. A little pricy but well worth it.
Thistle
2012 FLTRU ,Ember Red Sunglo, painted inner fairing, WO 515 Chubby bars, 14"and 16" dark smoke Windvest, J&M 6 speaker Rokker system w/ 500W amp, Zumo 665 Road Tech G.P.S. w/Iron Aces mount, Mustang "Super Touring w/backrest, Fuel Moto air cleaner,2-1-2 headpipe, SuperTrapp 4" Stouts, Wood WT555 cams, Wood lifters, SE adjustable push rods,Power Vision tuner, Foorboards moved out 1" and forward 1"
Old 11-05-2012, 06:16 PM
jacknife's Avatar
Nice to hear some good reviews, Thanks. I have decided it will be on my list to do this winter along with a Baker +1.5 oil pan I think will be a major improvement.
Old 11-05-2012, 06:33 PM
jimmyray11349's Avatar
jimmyray11349 jimmyray11349 is online now
I have the Jagg 10 row Fan Assisted and it does a great job. my bike cruises 1 or 2 up at 75-80 mph and temps range from 190- 205, even in the hot summer months. I think my temps dropped 25 degrees when I added the Jagg. Worth the money. $400 from Direct harley parts.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
Old 11-05-2012, 07:20 PM
tmd tmd is offline
Believe it or not but those temps are perfectly normal and your engine is actually designed to run that way. Spending all that money on a different cooler and oil pan may lower the temps a few degrees but in the end there is no real advantage and you will be left with a lighter wallet. Think about this for a minute. H-D is cranking out almost 300,000 bikes a year. A majority of them stay bone stock except for maybe and air cleaner and pipes and they run for tens of thousands of miles without issue.
Of course reading these fourms you would thing the sides of the roads were littered with twin cams with melted engines becuase you didn't spend a bunch of money on unnecessary accessoried to make your engine run cooler.
Ride the bike the way it is and spend that hard earned money on more important things like chrome.
Old 11-15-2012, 09:58 PM
Nevadasun Nevadasun is offline
Coming back from Sturgis in 2011 we were runing the bikes 70-75mph in 108* temps (I live in Las Vegas) on Interstate 15. The bike did quite well, no issues, however after that I installed Harley's Premium oil cooler and cutted the "CAT"...I feel much better about it all now. The winter mods I'll be doing will insure the bike will run even cooler.
Old 11-16-2012, 05:47 AM
smitty901's Avatar
If you already have a stock HD oil cooler why not give this a try it worked for me.
Cost is not to bad easy to install and works
http://bigskyfan.tripod.com/id10.html
