11-16-2012, 11:10 PM
harley wind deflectors
Picked up a set of harley wind deflectors at the swap meet (no instructions).
these: http://www.surdyke.com/AdvPartInfo.a...umber=57000063
mounted them with the big clamp on the engine guard and the small clamp on the gas tank bolt. doesnt fit real well. and don;t see how this placement reduces the wind on the rider.
Have I got them on correctly?
How exactly does the small clamp attach to the tank bolt? I have it on the outside of the rubber cover over the end of the bolt. not very solid.
11-17-2012, 06:48 AM
On mine, I have the small clamp between the frame and the tank mount. You will notice that there is more warm , or hot, air moving toward your legs when you are moving. I had mine on for a few days this summer, but took them off again, until temps started to get colder
'12 RGU - Big Blue Pearl
11-17-2012, 07:16 AM
Do a search on the forum. There are some older threads on this. I believe the don't fit quite rite on some years but I don't recall what years. Seems like someone on here found a way to make them work.
11-17-2012, 08:45 AM
What year bike do you have? I think that in 09 there was a fuel tank recall and some had problems installing the wind deflectors on the 09 models. The small tab on the wind deflectors goes between the fuel tank mounting tab and the frame of the bike not on the head of the mounting bolt. There are other threads on this forum that post pics of the correct way to mount them.
11-17-2012, 09:10 AM
You need to remove the rubber covers on the gas tank bolt before installing. There are no instructions included in the package. Good luck.
11 FLTRU 103 Red Hot Sunglow
11-17-2012, 09:28 AM
I have the HD wind deflectors on my bike and the rubber covers are still on my tank bolts so if the deflectors are installed correctly there is no need to remove the rubber tank bolt covers.
11-17-2012, 10:51 AM
I have the 2009 RG.
When I searched for harley wind deflectors I got 10 pages of threads.
I did learn that apparently was a recall on the tank mounting. How does one tell if the recall has been done?
11-17-2012, 11:11 AM
Take them and your glide to the local dealer. They are stock on the new bikes. Look at how they are mounted on the new ones and do the same.
11-17-2012, 04:18 PM
Okay, I started this last night in the garage with a drop cord light. This morning pulled bike out into sun light. so much easier. I drilled deflectors. I snapped deflectors on engine guards rotated back to rubber covers on tank bolts. put a zip tie on the deflectors. Done. While the didn't snap onto the tank bolts they are not going anywhere.
Now to see if they make a difference.
thanks for help.
11-17-2012, 04:38 PM
Originally Posted by opr1945
I have the 2009 RG.
Looks like you got the deflectors taken care of but if you still want to know how to look if any recalls are open on your bike you can go to the HD website and take a look. Click on the link and under the "Maintain Your Bike" section there is a place to look for any open recalls.
http://www.harley-davidson.com/en_US...bmLocale=en_US
