Starter crunch? - Page 5 - Road Glide Forums
Old 11-16-2012, 04:31 PM
rlaf75's Avatar
rlaf75 rlaf75 is online now
Originally Posted by rageglide View Post
I still don't believe the compensator will fix kick back. I researched the compensator problems with the 96" and up and all I ever found were issues with excessive wear and noise. The compensator in my 2012 is sure as hell loud so that backs that up.. lol
Harley went to auto compression releases in the 103's for a reason, and It's a safe bet they did it to address the starter kick back problems. Travel limiters work well in my experience, but they can be noisy. Not that the lifters in the 103" aren't noisy at start up already...
Long story short, I hate to say this and I hope you prove me wrong, but I suspect you will still have starter kick back problems with the new compensator.
I dont know but its been about 8k miles since i did the comp and i havent had any issue.
Old 11-16-2012, 10:12 PM
Believe what you want but eventually you will go with the SE compensator or compression releases.
08 FLTR candy red sunglo, 103 Stage II, Woods TW-222 cams, V&H Dresser Duals with Monster Rounds, Thundermax tuner, Willy Shiny Wheels and Forks and a bunch of other stuff.
  #43
Old 11-17-2012, 03:57 PM
I believe you, but I just don't understand why it helps. If kick back is going to happen. it's going to happen no matter what, compensator or no compensator. That's why compression releases and ignitions that don't fire initially help.
Anyway... I'm just trying to understand... :-)
  #44
Old 11-17-2012, 04:17 PM
rlaf75's Avatar
From what i understand, a bad or weak comp causes slack in the primary chain which in turn can cause the motor to kick back when trying to start and cause issues with the engagement of the starter to ring gear.
  #45
Old 11-17-2012, 07:52 PM
A bad/weak compensator can't create slack in the primary chain. Slack is controlled by the chain adjuster. The weak compensator softens the connection between the chain sprocket and the crankshaft. That said, I'd guess the slack chain take up accounts for most of the 'crunch" sound, (that and the one way bearing in the starter bendix being forced backwards).
In my opinion the bad/weak compensator could make it harder for the starter to push through a cylinder on the compression stroke in a similar way that a weak battery does.
So I still don't see new compensator as the "fix". It's like getting a new battery. So it's going to be an improvement.
Bleeding off the pressure induced resistance is a more reliable fix. Which is why compression releases are now standard issue for the big inch motors from Harley.
  #46
Old 11-17-2012, 08:48 PM
rlaf75's Avatar
All i can tell you is i had the starter grind, crunch or whatever you want to call it. I 1st rebuilt the starter and it still made the crunch. I then replaced the stock comp with the se comp and all has been great since. Not only did the starter crunch thing disappear, it shifted better, and finding neutral was easier and this my just be me but the bike felt more responsive and just felt better. Im sure the MoCo started putting in compression releases on the motors for a reason but mine is a bone stock 2009 96"er. I replaced the comp at around 19k miles and with 27k miles currently with the factory original battery and shes been without issue. I would highly recommend replacing the stock comp on the bikes with the previous comp design.
  #47
Old 11-17-2012, 08:55 PM
The SE compensator has a different ramp angle and stronger springs then the stock compensator, that is why it makes a difference.
  #48
Old 11-18-2012, 01:32 PM
Supposedly my 2012 has the "SE Comp" from the factory. I guess I'll never know of what you've dealt with in the past. Since we're at the same place now. Not to mention I have compression releases. :-)
I do think the newer style compensators are rather noisy...
Insurance
Please select your insurance company (Optional)
