Installing the Jackpot 2-1-2 with before and after Dyno tunes - Page 2 - Road Glide Forums
Old 11-18-2012, 06:39 PM
With this new fangled (to me) gearing I wonder what the norm is... My last dyno tune was done in 5th, and I think the 6 speed 5th is pretty close to the same.
I'm interested in the results you obtain before and after so will be keepin eye on this. I didnt' dyno my bike before installing the 2-1-2. It's an improvement, but I'm far from optimal at the moment. Still deciding on a nice set of slip-ons that will work with future mods...
Old 11-18-2012, 07:21 PM
skratch skratch is offline
Originally Posted by sloride View Post
well my 2-1-2 haedpipe arrived today well packed, in great shiny condition except they forgot to do the internal creamic coating.
Ok got my baseline dyno run done today by Ed at "The Dyno Difference"
i'm missing something here. on one day, 'they forgot...' next day, 'here's the numbers'...... what happened with the internal coating? i know there was a thread on the site which talked about a new thermal coating. is that what happened?
Old 11-18-2012, 11:03 PM
sloride's Avatar
sloride sloride is offline
Hey Skratch,
This was the baseline run before installing the 2-1-2 Jackpot.
Jamie with Fuelmoto has assured me that although they changed the internal coating it is as good as the original.
I started tearing down the exhaust system today and will have Ed Dyno tune it
Karl
2013 FLTRXSE2
Old 11-19-2012, 08:54 AM
sloride's Avatar
Hey Rage,
I talked with Ed this morning and he confermed that these were 4th gear pulls. He said 5th gear pulls wuld have raised the #'s a couple of points higher, but that would have taken the bike tires higher than their MPH rated speeds.
I am doing this to understand what I gain from adding a good exhaust and Dyno Tune. I will keep you posted.
Karl
2013 FLTRXSE2
Old 11-19-2012, 09:13 AM
Hey Skratch,
thanks. good to know that your pipes were indeed coated, and that all new fuelmoto pipes would be this way.
good luck with your tuning.
Old 11-21-2012, 10:54 AM
fuelmoto's Avatar
fuelmoto fuelmoto is offline
EFI tuning and Exhaust Expert
Looks good so far also note the Dyno Difference uses a DynoStar dyno which is a bit different than Dynojet dyno's. You are in good hands with Ed.
Jamie Long / Fuel Moto USA
Dynojet Power Vision info is here www.fuelmotousa.com/powervision.htm
The USA's source for EFI Tuning components and exhaust www.fuelmotousa.com www.jackpotmufflers.com
Contact 877-729-4754
Email jamie@fuelmotousa.com
Old 11-23-2012, 11:05 PM
MyGlide MyGlide is offline
Ed knows what he's doing. He's tuned both my builds on my fatboy and my stage 1 FLTRX. I drive 3 hours to see him, well worth it IMO.
2012 FLTRX 78hp/99tq SAE
2008 FLSTF 117 138hp/132tq SAE
Old 11-28-2012, 06:23 PM
sloride's Avatar
Ok I got the Jackpot 2-1-2 installed and fired it up today.
I absolutely love the sound. Very crisp with a good throaty pop. Not as loud as a 2-1 but a little deeper sound
The heat shields did not Line up on the new head pipe as well as the stock pipe. I guess this is to be expected, it is after all a different pipe. It looks OK, but not as clean as stock.
Ed will Dyno tune it tomorrow and I will post the results
I am already much happy
Karl
2013 FLTRXSE2
Old 11-29-2012, 05:56 PM
sloride's Avatar
Ok, the #'s are in. Ed will email me the dyno sheets tonight and i will post them
Stock #'s
STD best HP 87.8 best TQ 110.00
SAE best HP 85.5 best TQ 107.1
With Jackpot 2-1-2 2" Rush cores and a dyno tune by ED at The Dyno Difference.
STD best HP 94.1 best TQ 121.4
SAE best HP 92.9 best TQ 119.8
all these #'s are based on 4th gear pulls. 5th gear made a little higher #'s, but I did not do a baseline in 5th gear to compare it to
The most impressive thing of all is the TQ being over 100#'s from 1800 RPM thru 4800 RPM
The throttle response is incredible and you better have a good grip when you crack this baby open in the lower gears.
Karl
2013 FLTRXSE2
Old 11-29-2012, 06:04 PM
Fire-Medic's Avatar
Stock #'s
Awesome, can't wait to see the sheets!
