iSimple - Road Glide Forums
Old 11-18-2012, 10:04 AM
.ShortBus.'s Avatar
.ShortBus. .ShortBus. is offline
Default iSimple
Has anyone bought the iSimple from IronAces?
Thoughts ? Pros and Cons?
I just bought my Gilde ... 2012 Pearl Yellow ...
I am looking to upgrade the audio as well..
Thanks ....
Paula
Old 11-18-2012, 11:07 AM
Triplej Triplej is offline
Use it and the Iphone Mount every time I ride. Works nicely.
Old 11-18-2012, 12:21 PM
jrich4411 jrich4411 is offline
I have one as well as the Iron Claw chrome mount. FWIW I have an issue with mine - when I first start the bike and the iphone it will play a song from 1 - 5 seconds, I will hear a tone and it will then skip to another song. after 6-8 minutes it will stop doing this and work fine, UNLESS I ride a bumpy stretch of road.
I downoaded a app that is a player with a 10 band equalizer built in. This problem does NOT happen when I use this other app rather than the built in iphone app. Not sure why.
I just ordered a second isimple cable that I plan on using in my SUV. I plan on testing it out on the bike first to verify that the first cable is bad & then send that one back for replacement.
Old 11-19-2012, 12:04 AM
02RK4CRUZIN 02RK4CRUZIN is offline
I've had the isimple from Iron Aces for about 10 months. Love it with their mount.
2012 FLTRX BBP
Fullsac X Pipe, CFR's and TTS, 12" Windvest
6.5" Focal speakers and Arc 125.2 amp
Old 11-19-2012, 05:34 AM
HD_Shock's Avatar
HD_Shock HD_Shock is offline
You most likely have the "Shake to Shuffle" feature enabled. Turn that off in the music prefs.
-phil
2011 FLTRX 103
Old 11-19-2012, 05:45 AM
Phil_FLTRX's Avatar
Phil_FLTRX Phil_FLTRX is offline
I think HD-Shock is right. My 1st iPhone used to change songs on me when I jogged. Damn it pi$$ed me off!!! Come to find out the shake to shuffle was on. Now I know.....
2011 Vivid Black FLTRX, 107" Rev Perf, Zippers Thundermax AT, Roland Sands Speed 7 AC, Iron Aces iPhone holder, 8" KW, V&H Duals & Black Widows, DDM HIDs, ARC 6.5's, S.E. ported heads, 30 tooth frt sprocket.
You never see a Harley parked outside of a Psychiatrist’s office, now do you.....
Old 11-19-2012, 06:45 AM
Still Grumpy's Avatar
Still Grumpy Still Grumpy is offline
What's not to Like about it.?
It charges my Iphone while allowing me to listen to Pandora all with one simple connection..
Its a nice clean looking install.
I say do it.
2013 FLTRX Road Glide Custom
2005 FLSTF Fat Boy
(Wife's but I ride it )
Old 11-19-2012, 07:42 PM
I didn't know that feature was an option - thanks Shock! I will still use the other app as having the equalizer does make a difference in the sound quality.
Old 11-19-2012, 09:38 PM
dikdark's Avatar
dikdark dikdark is offline
I won mine @ SWI and have used it since. Well worth it. Hardest part on the install was sucking the gas out of the tank before taking it off to run the wires. Very clean set up. Highly recommended.
07 RG Vivid Black
FLHX fascia
Stage 1, SE pipes DS baffles,
+2 Sweepers, chrome quickly fading to black
Old 12-07-2012, 02:40 AM
emwolb emwolb is offline
Default isimple question,.....
a few days ago i got the isimple wiring setup from ironaces too. i was wondering why the instructions say that you have to remove the fuel tank. looks like the tank console is removed anyway in the process. isn't there plenty of room for the wires to lay between the tank and the chrome tank console? from reading the instructions with the great pictures in the install sheets, it looks like it'd be a no brainer that the gas tank doesn't need to be removed. perhaps i'm missing something here.
