dragos 107 stage 2 - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Post Your Dyno Results
Post Your Dyno Results Post your Dyno Results here. Let's see who is HOT!
Old 11-18-2012, 06:00 PM
bpt-bagger's Avatar
bpt-bagger bpt-bagger is offline
Default dragos 107 stage 2
Here its is dragos stage 2 kit dyno results
107.5 hp/118.2 ft-lbs
bike pulls like an animal. feels great
techno research direct link tuner
107 ci kit 10.6 compression (oem jugs Bored)
stage 2 heads
tman 625 cam
dragula 2 into 1
se ac
s&s push rods
gaterman lifters
rivera primo pro clutch
Old 11-18-2012, 06:23 PM
connector's Avatar
connector connector is offline
Thumbs up
Nice flat top and them numbers are great . Got to like it i bet
09 FLTR 103 Stage III
J Prescion Heads \ 10.5:1 \ T-Man 590 cam \ ThunderMax tuner \ Feuling cam plate and tensioners \ Jaggs cooler \ Progressive front end \ Dragos SC series pipe \ Top Shop Bags \ Hawg Wired ZX speakers 500 Watts and Lots more
Old 11-18-2012, 08:52 PM
mocotom's Avatar
mocotom mocotom is offline
Rob is one of the best tuners on the east coast.
2005 RG 98cu in
Old 11-18-2012, 09:22 PM
tmd tmd is offline
Nice numbers but whats up with that graph. HP/TQ are suppose to cross at 5250 not 4750? That and the numbers are off by 10 on each side.
Old 11-18-2012, 09:36 PM
bpt-bagger's Avatar
the first run was with the break in map and the rev limiter was set at 5000 rpm. the last run the rev limiter was set to 6200. my builder and i are good friends with Rob. these guys know how i like to romp on my bike so during the break in they wanted to "keep me honest"
Old 11-19-2012, 07:33 AM
tmd tmd is offline
It doesn't matter if the rev limiter is set at 100 rpm's or 100,000 rpm's, HP/TQ cross at 5250.
Old 11-19-2012, 07:40 AM
bpt-bagger's Avatar
I'm not here to argue if you think you know more the my tuner and what he told me so be it lmao
Old 11-19-2012, 08:55 AM
akjeff akjeff is offline
HP and Torque are only going to cross at 5252rpm(not 5250) on a graphical comparison, if the same scaling is used for both traces, which in this case they aren't. There's nothing "wrong" with the guys numbers, or bike. The dyno operator simply chose a different scaling between the two, for whatever reason.
Jeff
2009 Vivid Black FLTR, 107" w/Dewey's PS heads, TMan 625, Jackpot 2/1/2 w4" mufflers, PV w/AT.
Old 11-19-2012, 09:02 AM
mocotom's Avatar
Your looking at a graph from a Dynostar dynamometer. The scale is staggered side to side for HP and TQ. That is why the intersecting points are at a different RPM than what your accustom to seeing on most Dynojet machine graphs
See Jeff already explained. Sorry
2005 RG 98cu in
Old 11-19-2012, 09:08 AM
laxinharley's Avatar
Bpt, who is your builder. Those are some nice numbers. Is he out your way in Bridgeport? Wanting to do something similiar although other mods are coming first. Thanks,
Scott
