dragos 107 stage 2 - Page 2 - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Post Your Dyno Results
Post Your Dyno Results Post your Dyno Results here. Let's see who is HOT!
Old 11-19-2012, 09:22 AM
bpt-bagger's Avatar
bpt-bagger bpt-bagger is offline
Thanks guys for clearing that up. Rob is sending me a new graph with the corrected scaling. Scott, ill pm you his info. Yes his down here on Bpt . If he okays me putting his info on here ill be sure to put it up. This forum has been a great source of info.
Old 11-20-2012, 07:05 AM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
It looks very good Rob did a nice job on the tune. Just need to fix scale. But the numbers dont lie.
Wait until you get the our 54mm throttle body on there Thats port matched to your heads. You will see at leaset 4/7 more hp easy.
I am glade you are happy. Just remeber those heads are set up for a blower spec like we talked so when you are ready for a procharger we just need to swap out cams to my blower cams and easy 160/170 hp.....
Originally Posted by bpt-bagger View Post
Here its is dragos stage 2 kit dyno results
107.7 hp/118.5 ft-lbs
bike pulls like an animal. feels great
techno research direct link tuner
107 ci kit 10.6 compression (oem jugs Bored)
stage 2 heads
tman 625 cam
dragula 2 into 1
s&s push rods
gaterman lifters
rivera primo pro clutch
www.dragosbikeworks.com
Old 11-20-2012, 09:29 AM
laxinharley's Avatar
Got your PM thanks for the info Henry..
Old 11-20-2012, 05:09 PM
bpt-bagger's Avatar
Thumbs up corrected scaling
Heres the correct scaling. Scott glad i could help.
