2011 CVO Roadglide Ultra suspension upgrade-HELP
I know there are a ton of posts regarding this subject. Mind boggling. Way too many choices out there. Here is my dilemma. I ride a 2011 CVO Road Glide Ultra-13"shocks(solo 50% of the time). I tried Progressive 940's from my local dealer as a demo. I liked the ride improvement in the twistys and on bumps and humps but it felt stiffer on normal roads(I could feel almost every imperfection in the pavement but no bottoming out, riding solo with virtually no pre-load). I felt that the ride quality was very similar to a stock Road Glide Custom-12" shocks. Also liked the fact that I could reach the ground better(I am 5'7" 180lbs). I didn't like having to remove the saddlebags to adjust the pre-load.(I wasn't comfortable just leaning the bags against my leg during the adjustment process due to the potential "stretching" of the electrical connections for the power locks and Ipod or worse,dropping the saddlebag on the ground by accident(CVO paint repairs are not cheap).
I have read many posts regarding the choices available(Bitubo, Ohlin, Progressive, Works, Legends and Arnott). I understand any shock that isn't air ride is going to require me to pull the saddlebags. I also understand i will not get the performance upgrade I'm looking for with an air ride shock. .
My dealer recommends using Progressive air draggers rather than Legend or Arnott; he gives his vote of confidence to Progressive because affordable suspensions is their business and he has seen his share of issues with the other air ride systems. I have found nothing regarding the AirDraggers. Anyone currently using them or tried and didn't like them? I did call Progressive and the 444's were recommended by them saying I would only have to remove my bags to adjust them twice a week(solo during the week and 2 up on weekends). I ride about 14,000 miles per year starting in April until late November.(that's about 26 weeks times 2 = 50 plus times a season to pull and replace the bags)
My Priorities:
1)Better ride comfort overall than stock HD shocks(gotta keep the BSR happy)
2)Fairly easy to switch setting from one up to two up
3)Better performance on twistys and bumps and humps
4)Lower was nice but not real necessary.(I am not willing to compromise ride comfort for better handling;after all it is a 900 lb touring bike not a sport bike).
I realize there is no perfect solution to what I am trying to accomplish.
Based on my priorities has anyone had the same issue and reached a compromise that is acceptable?
I am also going to install Progessive Monotubes at the same time.
"Life is not measured by the breaths we take, but by the moments that take our breath away."
***Charcoal Slate/Black Twilight
