Dim the Dash Lights - Road Glide Forums
Old 11-19-2012, 02:29 AM
Uncleford Uncleford is offline
Default Dim the Dash Lights
Hey guys, I am looking for a way to dim the dash lights on my 11' RGC. The problem I am having is during night time rides the gauge, radio, Hi beam and cruise lights really distract me. It helps if I use my hand to block them but that isn't really feasable after a few minutes of riding. Even in my cages I always dim the lights real low so I have better night vision on the road.
I looked at some old threads but didn't get anywhere with it. Has anyone put a dimmer somewhere in line with the lights to fix this issue? Thanks!
'11 RG - Vivid Blk -103ci pwr pk
Old 11-21-2012, 11:25 PM
Peewee's Avatar
Peewee Peewee is offline
I think (meaning not sure), that all the lights in the Speedo and Tach are LED's. Might be a touch different than just putting in a dimmer switch. With the lights below the gauges (bright, neutral, oil press), I think those are some kind of incadesant, so a dimmer switch of sorts may work. I would suggest getting in touch with the guy that changes the colors of the lighting in the speedo/tach, he may be able to that or steer you in the right direction. There are several threads on his work, but I can't remeber his website, but I'm sure somebody will help with that!
"Know Thyself"
Old 11-22-2012, 09:55 AM
Cakeman1's Avatar
Cakeman1 Cakeman1 is offline
Not sure if this helps, but here is part of a thread about changing the colors, that might help along with info on the bulbs, I believe the name is Marty who can help with replacements if you don’t want to try.
http://www.roadglide.org/showthread....=gauges&page=4
http://www.roadglide.org/showthread.php?t=25624
God grant me calm seas, A helpful wind, A good catch,
And a safe return home
Currently:
Hopefully an RGU soon
79 FLH Electra Glide (ya know - shovelhead!)
82 GS1150 (when the need for crazy speed)
Too many others have come and gone,
Old 11-22-2012, 10:09 AM
Cakeman1's Avatar
Hey I got intrigued with the idea and went out on google. Guess what, it brought me back here.
http://www.roadglide.org/showthread.php?t=749
Good Luck
Currently:
Old 11-26-2012, 09:33 PM
Okay kewl, thanks for the links guys, I will start there. I have to do something about it and do not want to use tape.
I will have to do this soon. Everytime I go out for a ride I forget about this..until it gets dark..
I will let you know what I find...
