Adding Accessory Outlet - Road Glide Forums
Old 11-27-2012, 08:43 AM
jimmyray11349's Avatar
jimmyray11349 jimmyray11349 is online now
Default Adding Accessory Outlet
I have a 2010 RGC. I want to add Accessory Outlet in my fairing right side pocket similar to one in left fairing pocket. Where do I power it inside fairing?
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
Old 11-27-2012, 09:16 AM
SurlyBoy's Avatar
SurlyBoy SurlyBoy is offline
There's an accessory wire and ground zip tied to the headlight wiring harness. Can't remember what color it is, maybe orange and white? There are spade connectors already crimped on the ends. I used it to power my bar end heaters.
While I was in there I ran an extra wire from there into the speedo housing. It's not hooked up to anything right now but it means I don't have to take off the fairing in order to get to it if I need to add an accessory.
2012 Vivid Black Road Glide Ultra
