Heated Seat Question - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Seating: seats, backrests
Seating: seats, backrests SEATING: seats, backrests for Road Glides
Old 01-02-2013, 11:03 AM
Triplej Triplej is offline
Default Heated Seat Question
For those of you using the HD Heated Seats, how long should it take for the seat to actually heat up to where you can really tell it is working?
I am looking at possibly purchasing a used heated seat from a CVO model and I can tell it is starting to heat up with the bike running in a few minutes but it does not seem to get all that warm. Does it take a while before you can feel the warmth or am I possibly looking at a seat with heating element issues?
Thanks in advance!
Old 01-02-2013, 06:47 PM
Ohiobellboy's Avatar
Ohiobellboy Ohiobellboy is online now
Mine likes to roast the boys within about 8 minutes on high and that's riding below 50*. I can tolerate it on low after that for about another 10 minutes and then I'm turning it off. My wife on the other hand can ride with that damn thing on all day it seems.
aka OBB
Old 01-02-2013, 06:50 PM
Thanks for the reply. I finally got a chance to try it out a little longer and it never got more than slightly warm. Must be on its way out. Good thing I got a chance to try before buy
Old 01-03-2013, 02:34 AM
Just curious on how it was wired to your bike. With mine being a CVO it's factory that way. I've read a lot where people have added them and powered them through the acc switch. I wonder if the voltage is different through that switch although I don't really understand how it could be.
aka OBB
Old 01-03-2013, 05:21 AM
RichieRichMRMC's Avatar
RichieRichMRMC RichieRichMRMC is offline
The accessory port is the same voltage as wiring something direct to the battery. The heated seat I have came with a factory style connector that plugs directly into the accessory port.
2013 BBP FLTRX
Old 01-03-2013, 05:37 AM
I figured it would be but never checked so I thought I'd throw that out there.
aka OBB
Old 01-03-2013, 07:29 AM
The accessory plug is where I had it plugged in.
Old 01-03-2013, 08:56 AM
Illiniroads's Avatar
Illiniroads Illiniroads is offline
Post toasty in about 10 minutes thru acc. Switch. I have the Sunray model. It adds about 2" to the height of the custom seat.
2012 RGC BIG Blue Pearl SE Stage II 95hp 107tq
2011 RS-S Can Am Spyder 106hp 77tq
Old 01-03-2013, 09:12 AM
ROADEAGLE ROADEAGLE is online now
You can make the seat You have heat
http://www.sargentcycle.com/harley.htm
Don't compromise when it comes to comfort. Our DIYHEAT Seat Heater System features our FINE WIRETM heat pad - designed specifically for motorcycle seats - and our exclusive ChilliTM Controller which offers full range heat, not just one or two settings like competing products.
The high-tech SARGENT Heat Controller provides the ultimate heat control - from high to low and anywhere in between. And, the adjustable power and brightness settings are displayed in a LED bar graph that shows the exact temperature setting day or night. It's completely water-proof and can easily be mounted anywhere within reach. It is small yet easily adjusted - even with a gloved hand. And, thanks to its pulse modulating technology, it isn't affected by ambiant temperatures.
Our FINE WIRE heat pad is thin, unobtrusive and virtually undetectable. In addtion, its shape is designed to fit the unique contours common to most motorcycle seats. This kit is designed for do-it-yoursef installation*
Kit includes components for one seating area:
One Fine Wire Heat Pad
One Chilli Electronic Controller
SAE Wiring
Splice Connectors
Peel and Stick Adhesive
Installation Instructions (Preview HERE)
*Re-installation of seat cover may require use of high power pneumatic staple gun or professional upholstery shop assistance. Professional installation is highly recomended or may be required for button fitted seats.
POWER DRAW. Each heated seating area (front or rear) is supplied with its own heat controller. Each heated zone draws approximately 2 amps (or 24 watts), and dual zone installations will draw approximately 4 amps (or 48 watts) at full pow
Works Great Easy install and you can adjust the heat any way you want
Old 01-03-2013, 09:17 AM
wenchal's Avatar
wenchal wenchal is offline
I kept the heated seat from my previous bike (08 CVO Ultra). The element finally went out this past Oct. I wound up replacing it myself. Was a pretty easly job and the replacment was same brand as what Harley had on there and preforms just as well. Gets quite toasty!
