1340 EVO motor upgrade - Page 3 - Road Glide Forums
Old 01-02-2013, 01:26 PM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
i thought mikuni had a adapter (found the S&S one,but not the mikuni one,but i knew i saw one someware)
kirby VEE TWIN RACING
7.14@189/4.49@167
Old 01-02-2013, 04:17 PM
my98glide my98glide is offline
of course I could also bump up to the 44mm CV carb....to many options all about the same price makes it hard to choose...lol
George's Trike Shop 713-418-0954
Roadsmith Conversions, Bad Dad, Baker Drivetrain, and Hawg Halters.
1998 Road Glide EVO project.
Old 01-02-2013, 04:57 PM
fxrs-sp fxrs-sp is offline
My fav is a CV 41.5 from Bob Wood........but VERY pricey. I was getting 44 mpg without a dyno tune
Old 01-03-2013, 01:11 PM
44mm CV would be good choice (like i said,i like CV`s,the bigger ones even more)
7.14@189/4.49@167
Old 01-03-2013, 03:24 PM
If you want to go to CV44 and retain Cruise control, you need to buy the "street legal" version - if you can find one. but I don't think HD sells it anymore. The "race only" CV44 doesn't have the CC bellcrank and you would need to swap the throttle shafts to add one. Not sure if you can swap with the CV40 shaft... I just opted to go without cruise control when I swapped to a CV44 on my RG.
In my opinion, a CV40 would be more than sufficient on a mildly hotrodded 80" Evo with stock, and even street ported heads. A CV44 probably would be noticeable on a dyno (few hp at the top end), or on a street ridden hotrod, but I would not expect to notice the difference on a heavy touring rig. I'll leave that answer to Kirby as I'm sure he has more experience in this area. As I mentioned I run a CV40 on my stroker... maybe one of these days I should install the cv44 I have on my bench and see how it runs. :-D
I like Woods cams, a lot! But I would never buy a Woods carb. Way to expensive to justify the end result. Heck you get most of what you'd want in a CV44. My opinion is based on my riding partners experience.
Old 01-04-2013, 05:21 AM
Hillsidecycle.com Hillsidecycle.com is offline
Send a message via AIM to Hillsidecycle.com
This is not based on opinion..........this is fact, if you want your 80"er to really roll.
Heads that move 150" @ 10".
Wiseco pistons
Wood 8 cam
S&S E carb/Thunderjet
Dyna 2000, or Crane HI-4
Thunderheader, Supertrapp, or other good pipe.
It'll hover at 95 hp, and 95 ft/lbs, with FANTASTIC fuel economy.
Been building this combination since the mid-1990's..........
Scott
Complete machine shop
Complete cylinder head shop
Dyno tuning
Extended Warranty Center
MMI Certified Mechanics
Stocking Dealer for;
S&S Cycle
Axtell Sales
Wood Performance
Horse Power Inc.
Andrews Products
Rivera Engineering
Bandit Machine Works
"Land Speed Record Power"
www.hillsidecycle.com
5225 South Main St.
Munnsville, N.Y. 13409
315-495-6650 phone/fax
M-F 8-5, Sat 8-12 or by appt.
Old 01-05-2013, 03:00 PM
well dont have cash for piston change...or woods parts for that matter....i have more time than money so i can wait for deals to come across.
