Fuel gauge different problem - Road Glide Forums
Old 09-19-2012, 08:53 PM
papa roc's Avatar
papa roc papa roc is offline
Default Fuel gauge different problem
I have an 06. When i turn on the switch, the gauge sweeps to full, But the low fuel light is on.
Here's what happened... Riding home had just under half a tank. Got caught in a little bit on rain nothing heavy. After riding about 20 miles, the gauge was showing full and the fuel light was on. Took of the cap, shake the bike,,and I can see gas. I know there are post here about this, but I thought this might be something different.
06 RG detachable tour pack,sissy bar and rack. J&M rokker speakers, CFR knockoff, lowering kit
Old 01-03-2013, 03:39 PM
papa roc's Avatar
Bump no advice?
Old 01-03-2013, 05:15 PM
SickRick SickRick is offline
Since you're getting bad readings from both the gauge and the light, it would suggest a problem with the sending unit inside the fuel tank. I'd pull the unit and see if something appears to be stuck.
Old 01-03-2013, 05:59 PM
tmd tmd is offline
If you say it happened after getting caught in the rain I would check your electrical connector to the sending unit for moisture or corrosion.
