Biketronics says no LE needed - Road Glide Forums
Old 01-03-2013, 02:07 PM
Sparkles Sparkles is offline
Default Biketronics says no LE needed
So I called up Biketronics to ask about a Load Equalizer for the 2013 CVO RGC. I noticed the one BT 801M appeared to be a six pin plug and I know that Custom Dynamics version was 8 pin for the CVO. She recommended the BT 801 which is an 8 pin...but it appeared to have a different configuration than the CD version. So not sure if that will work?
But as we were talking, she said that I wouldn't need an LE for just doing front signals. That I could set up my bike to adjust the flashing to slow down by disconnecting the battery a couple of times.
Has anyone tried that? I wouldn't mind saving some $ if I don't really need it. .
Old 01-03-2013, 08:45 PM
Ohiobellboy's Avatar
Ohiobellboy Ohiobellboy is offline
Thread on the CVO site that a member just put front LEDs on his bike. He did not do the rear and is not using an LE but said if he did the rears then he would need to add one.
As far as the battery disconnect, I have no idea if he needed to do that or not.
aka OBB
Old 01-03-2013, 09:08 PM
RGCBandit's Avatar
RGCBandit RGCBandit is offline
A load equalizer is required if you have LED front AND rear signals. So no, it is not needed for one set only.
Old 01-03-2013, 09:37 PM
JJSW1283's Avatar
JJSW1283 JJSW1283 is offline
Question then. If you end up doing both, would you need equalizers for both front and back or just for one?
Old 01-03-2013, 09:44 PM
RichieRichMRMC's Avatar
RichieRichMRMC RichieRichMRMC is online now
One LE covers the entire bike but you only need it if you change front and back.
2013 BBP FLTRX
Old 01-04-2013, 12:02 AM
Ok, cool! I guess I won't need it for the Dynamic Ringz that I ordered from CD.
Thanks!
Old 01-04-2013, 12:25 AM
I ordered alloy art ones from Eastern. I know a couple people on here with the same set up that swear they didnt need a LE with fronts only. Good luck.
2013 BBP FLTRX
Old 01-04-2013, 05:17 AM
Do you have a link handy to pix of yours with those lights?
aka OBB
Old 01-04-2013, 09:18 AM
They arent here yet. Waiting on the brown truck:banghead: Goneblack has them on his though in black.
2013 BBP FLTRX
