Arnott Air Suspension or Progressive 944s - Road Glide Forums
Old 01-09-2013, 07:50 AM
Batbiker Batbiker is offline
Default Arnott Air Suspension or Progressive 944s
Has anyone ridden or tested the two different types of suspension? Does the Arnott require the addition of the gauge and toggle switch? I have the '13 RG CVO ANN and I believe the stock shocks are 12" or 12.5"
Old 01-09-2013, 02:14 PM
GoneBlack's Avatar
GoneBlack GoneBlack is online now
I have never ridden a bike with the 944s (have 444s on the shelf though) and I have Arnott air ride installed.....but the two are completely different animals
Air ride will require wiring the compressor and a switch. The gauge is completely up to you and wether you want to run one or not......I have one, but not running it. The air ride rides "good", better than stock, but the ability to lay your bike, out when park is just cool can't be done with a fixed length shock. If the "cool factor" and a decent ride is what your looking for, this option is for you
The 944s I'm sure will ride night and day better than air ride, and 200% better than stock. but your stuck at the fixed length of the shock. If the absolute best ride quality (of the two) is what your looking for, this would be the option for you
Oh and your stock length shocks should be 12"
2012 Road Glide Custom....The build: http://www.roadglide.org/showthread.php?t=19311
CA spring Ride, book your room http://www.roadglide.org/showthread.php?t=26443
Old 01-09-2013, 04:49 PM
The 944s are 13" length but the stock are 12". I read that once you sit on the bike it drops 1" or more. Will the 944s at 13" screw up the balance of the ride? Also thing about the progressive fork spring kit. Has anyone done the two together? Any suggestions?
Old 01-09-2013, 05:03 PM
GoneBlack's Avatar
Yes the 944s are 13" and your correct with the sag built into the setup they ride at 12" and no it won't through the balance of the bike off.....just ride a lot better then stock
Up front, 95% of the folks on here are going to recommend the progressive monotubes......can pick stock height, -1" or -2"......I'm running -2" up front Arnott air out back, I love the look and ride of both
What are your suspension goals?
Old 01-09-2013, 05:06 PM
Mike U's Avatar
Mike U Mike U is offline
I bought a set of Progressive 944-4002UT rear shocks after all the research I found on this Great Forum. I am hoping they arrive soon so I can install them this weekend. From what I've read everyone speaks very highly of them. I also ordered the Progressive Monotubes -1 to complete the suspension.
Best of Luck on your decision.
Mike U.
USMC 1975-1977
2012 RGC Vivid Black,Drago's True Duals&Mufflers, PC5,& Zipper's A/F.Monotubes -1 & 944-4002, Wild One Outlaw 12", Daymaker & Hawg Wired 6 Pack with Tweeters.
Old 01-09-2013, 05:15 PM
mitchdm's Avatar
mitchdm mitchdm is offline
I am runnin the 940's with Monotubes ~ bike does drop an inch when you sit on it ~ Progressive calls this Preload ~ using my fat ass to make it sit correct ~ I Love this Combo ~ Mine is also a CVO ~ now it rides & handles better ~ no cool factor other than miles ~ I think cool is in the odometer, the more miles the cooler. I will let you know about the Arnott Air ~ A friend of mine has one that I'm ridin in the next week or tow.
Old 01-10-2013, 04:12 PM
07glider 07glider is offline
I have ridden all three, arnott bilstiens, aldins, and progressives. The progressives are a better ride in my opinion, but the arnott's have the "cool" factor of being able to drop the bike when parked or adjust while ridding. Just my 2 Cents.
Old 01-19-2013, 10:21 PM
02heritage's Avatar
02heritage 02heritage is offline
Batbiker, if the change is for comfort, than I would put the progressive on. I have had the Arnott on a different bike, It does look good but the ride was not there. I will not have another air system unless the bike is for SHOW ONLY. That was all this bike was good for, sold it and bought the Roadglide.
2007 RG, 103ci, Harley Blade wheels, Painted Dash
