Sert map needed.......... - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Road Glide Map Section
Road Glide Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
Old 01-10-2013, 09:10 PM
BAM BAM BAM BAM is offline
Exclamation Sert map needed..........
I have a 2013 RG with a SE air cleaner, V&H power duals, and CFR's can anyone get me a map for my SERT ????
Old 01-10-2013, 10:00 PM
faststan's Avatar
faststan faststan is offline
You will need the software and cables to hook up to a PC. The maps are on the PC software. The other option is take it to get dyno'ed to create a custom map.
11 FLTRU 103 Red Hot Sunglow
Old 01-10-2013, 10:48 PM
I got the tuner today and the disc and cables I will pick up tomorrow. I was just wondering if there is a place I can get a map of exactly what I have ???
Old 01-10-2013, 10:49 PM
piesik650 piesik650 is offline
there is a map on there for vh pipes and air cleaner. that's what I used with my rineharts when I had them
Old 01-10-2013, 10:53 PM
Awesome thanks.... I'll check into that
Old 05-08-2013, 09:51 AM
welcomingwar's Avatar
welcomingwar welcomingwar is offline
Be sure to click through all the maps. I think I ended up using the map that had Race Exhaust, SE Air Cleaner, 255 Cams for mine and then used the smart tune to tailor it.
