Doesn't seem right. - Road Glide Forums
Old 01-07-2013, 05:34 AM
Ranger75's Avatar
Ranger75 Ranger75 is online now
Default Doesn't seem right.
Hey all, This didn't seem to fit in any one sub-forum. When I apply my rear brake (12 FLTRX - 8500 miles), I feel a distinct "clunking", almost like a loose suspension part. Has anyone else experienced anything similar? It doesn't feel like a scraping or pulsing but more like a clunking you would feel on an old rattle trap car suspension when hitting bumps except this happens when the road is smooth as well.
2012 FLTRX: -Dragula true duals, Cee Bailey's TRSSC Dome, Wild1 12" Black Outlawz, Matching Tour Pack w/QD Docking kit, Air Wing TP Lid Rack
VP Rolling Thunder GA Chapter 1
Old 01-07-2013, 05:44 AM
Bandit 7's Avatar
Bandit 7 Bandit 7 is offline
Have you checked the brake caliber and rotor? If this only happens when applying the brake I would start there.
Old 01-07-2013, 05:59 AM
I had a similar problem, took it to the dealer under warranty, it had something to do with the ABS, I forgot what exactly it was. It didn't happen until they replaced my rear brake switch after a recall.
Old 01-07-2013, 06:29 AM
Ranger75's Avatar
Thanls Bandit, I did - took the bags off & put it on the lift so the rear could spin freely. I checked the rotor, calipers, pads and shocks & nothing seems amiss / loose. I also put in gear while running and applied the rear brake & the only "clunking" was due to lugging the motor. I'll have my 10k service soon & will have the dealer check but was concerned it might be something needing sooner attention.
Old 01-07-2013, 06:30 AM
Ranger75's Avatar
Thanks Dbell - No ABS on mine unfortunately...
Old 01-07-2013, 08:23 AM
Big_gary's Avatar
Big_gary Big_gary is offline
Ranger this my have some thing to do with the compensater in the rear wheel. That could transfer vibs all over the bike.
10 FLTRX , 13" Madstad
If I have to explain ,you wouldn't under stand anyway.
Old 01-07-2013, 10:45 AM
Ranger75's Avatar
Thanks Big G. I'll be having new tires put on at the 10K service, hoping they can square whatever it is away when they reinstall...
Old 01-14-2013, 05:47 AM
Ranger75's Avatar
Just an update - I aired my (stock) shocks to 40 PSI and took a ride yesterday with my wife. Didn't notice any "clunking". Hopefully that's all it was.
