Engine Heat Shield for 2-1 Dragula - Road Glide Forums
Go Back   Road Glide Forums > Roadglide.org Site Sponsors Forums > Dragos BikeWorks
Dragos BikeWorks Dragosbikeworks is an engine expert, give him a call with all your engine questions. www.dragosbikeworks.com
Old 01-13-2013, 09:51 PM
Q-Hog's Avatar
Q-Hog Q-Hog is offline
Default Engine Heat Shield for 2-1 Dragula
Frank, do you know of any engine heat shield that connects to the frame that can fit with your 2-1 pipe? I tried the one that HD sales and the bend in the pipe prevents it from fitting.
Old 01-13-2013, 09:55 PM
Z-SHARK's Avatar
Z-SHARK Z-SHARK is offline
I'm very interested in this also for my Dragular.
Fill with Gas... Twist throttle... Enjoy Life
Old 01-13-2013, 10:17 PM
Q-Hog's Avatar
The heat emitting while riding slow is overwhelming.
[/SIGPIC][SIGPIC]
Old 01-14-2013, 05:30 AM
tj316's Avatar
tj316 tj316 is offline
I run the Kuryakyn one and it works or you can notch the Harley one
Old 01-14-2013, 07:12 AM
+1, I have the Kury also.
Sent from my SPH-L710 using Motorcycle.com Free App
2010 FLTRX, Rev Performance 107, S&S 570G cams, Head work, Crank trued and welded, timken conv, CM 21" Titan, TMax, Dragos Dragula, Top Shop bags and fender, Holeshot LED's, Carlini Bag Drag bars, too many more things to list, and suject to change.
Old 01-14-2013, 09:08 AM
Q-Hog's Avatar
Thx. Can you post a pic of it.
[/SIGPIC][SIGPIC]
Old 01-14-2013, 03:25 PM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
No you would have to notch the HD one.
Old 01-14-2013, 04:08 PM
bigpete1's Avatar
bigpete1 bigpete1 is offline
i use the stock harley one with dragula .i notched it it works just fine easy to cut i will try to find a pic.thanks pete
05 fltri 95" 06 fxdi 95"03 flht120" 11 fltrui 103
Old 01-14-2013, 06:45 PM
Q-Hog's Avatar
Thx . Do you have A close up pic?.. Those anyone have a pic of the Kuryakyn model installed with Dragula 2-1 that you can post? Thx
[/SIGPIC][SIGPIC]
Old 01-14-2013, 07:02 PM
Fire-Medic's Avatar
I'm worried about notching mine because they're match painted........
