You can make the seat You have heat
http://www.sargentcycle.com/harley.htm
Don't compromise when it comes to comfort. Our DIYHEAT Seat Heater System features our FINE WIRETM heat pad - designed specifically for motorcycle seats - and our exclusive ChilliTM Controller which offers full range heat, not just one or two settings like competing products.
The high-tech SARGENT Heat Controller provides the ultimate heat control - from high to low and anywhere in between. And, the adjustable power and brightness settings are displayed in a LED bar graph that shows the exact temperature setting day or night. It's completely water-proof and can easily be mounted anywhere within reach. It is small yet easily adjusted - even with a gloved hand. And, thanks to its pulse modulating technology, it isn't affected by ambiant temperatures.
Our FINE WIRE heat pad is thin, unobtrusive and virtually undetectable. In addtion, its shape is designed to fit the unique contours common to most motorcycle seats. This kit is designed for do-it-yoursef installation*
Kit includes components for one seating area:
One Fine Wire Heat Pad
One Chilli Electronic Controller
SAE Wiring
Splice Connectors
Peel and Stick Adhesive
Installation Instructions (Preview HERE)
*Re-installation of seat cover may require use of high power pneumatic staple gun or professional upholstery shop assistance. Professional installation is highly recomended or may be required for button fitted seats.
POWER DRAW. Each heated seating area (front or rear) is supplied with its own heat controller. Each heated zone draws approximately 2 amps (or 24 watts), and dual zone installations will draw approximately 4 amps (or 48 watts) at full pow
Works Great Easy install and you can adjust the heat any way you want
