Compression Release - Page 2 - Road Glide Forums
Old 11-24-2012, 10:46 PM
skratch skratch is offline
MSRP: $150 EACH. INCLUDES ONE PLUG, ADDITIONAL PLUGS ARE $20 EACH
dang, that is one expensive spark plug.
Old 11-25-2012, 06:11 AM
RoadGlide0611 RoadGlide0611 is offline
How much does it cost to have manual compression releases put on? That wasn't done to mine when I had it done. They told me it wasn't necessary. I have 10:1 compression.
Old 11-25-2012, 07:24 AM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
we get 140.00 (includes USA made releases)
kirby VEE TWIN RACING
7.14@189/4.49@167
Old 11-25-2012, 08:17 AM
smitty901's Avatar
Starters and batteries are cheap who needs CR.
We see it over and over built it but on the cheap leave out the ACR who needs them.
You need them even the 103 factory comes with them HD did not put them in as a selling point there is a reason.
Old 11-25-2012, 09:22 AM
Well that's not exactly how it went down. I was told by the builder that I didn't need compression releases because my compression was only 10:1. I know now I should have had em put in, but I tried to take the advice of the guy doing the build. It wasn't a personal friend or anything, in fact I had to hall my bike 10 hrs each way. Now I love the build, just wish I had compression releases.
Old 11-25-2012, 04:38 PM
rageglide rageglide is online now
Dynamic compression ratio, or ColdCrankingPressure will be a better indicator of a requirement for comp releases. Anyone who has done a compression test with the throttle closed vs wfo likely understands why. It's harder to know the CCP based on the numbers because CCP is dependent on more factors than a mechanical ratio.. CCP is an indication of how good a pump you've got.
Exaggerated examples:
- An engine with static 10:1 using a cam designed for 12:1 will not need comp releases and should spin over very easily - plus if it had comp releases may not start at all.
- An engine with 10:1 and a cam designed for 8.5:1 (think stock) will likely be unstartable without comp releases because you may not even get the engine turned over.
The statement that a build with 10:1 doesn't require CR's probably had a cam recommendation behind it.
Old 11-25-2012, 05:34 PM
Good explanation. I may not need compression releases. My bike starts fine. I just had to replace the starter clutch and compensator and so I was just wondering when i started reading this thread.
Old 11-26-2012, 07:20 PM
stogieluvr60 stogieluvr60 is offline
Default Releases
At what compression should you have releases?
That would require a cold cranking compression test. To say that a particular compression ratio requires releases is ....well...with all due respect, not enough info. One could have a certain comp. ratio as determined by pistons and combustion chamber volume (and other factors) and depending on cam grind, releases may or may not be needed. Check your ccp.....anything over 185 psi could benefit from some sort of compression releases. ACR's are great....when they work. Manuals are great... when you remember to push the button. Redundant systems cover you best. Hope this helps.
Old 11-26-2012, 07:48 PM
Deweys Deweys is offline
Those deals fail
Drill for ACRs or manual releases, both done at my shop and many others
Old 11-26-2012, 10:24 PM
Ironrider's Avatar
Thanks for all the feedback.
