01-01-2013, 10:32 AM
anyone install the saddlebag power outlet?
Since my tourpackvus set up quick detach, I'd like to get the outlet for the saddlebag. Anyone else have one?
2012 FLRTX Chrome Freaking Yellow
01-01-2013, 12:23 PM
I put one in. It connects with an SAE cable connector to the battery so taking the bags off is not a problem. Just unplug and remove. If you have a Battery Tender connector on your bike, you're halfway there.
06 Road Glide. Making it mine. Next year......the motor
01-01-2013, 02:10 PM
I put one in my detach tour pak and the wire to plug into was already in there so I just unplug it when I unplug the other wires to take the pak off
2012 FLTRU vivid black
life has no remote
get up and change it yourself
01-09-2013, 11:33 AM
I got one too. Quick disconnect is super easy.
Bear, VP, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, 4 pt bracket, stealth rack, side bag aux power, HD bag lid organizers, sundowner seat, black KW 8".
01-09-2013, 01:03 PM
So, anyone else out there have experience with the SADDLEBAG power outlet?
01-10-2013, 01:26 PM
I put one in my left saddlebag. Works great, plugs in to my battery tender plug. Quick to disconnect and remove.
01-10-2013, 04:14 PM
Great Info Fun Chuck!
Thanks for sharing.
I think I'll put one in my Left saddlebag too.
Mike U.
USMC 1975-1977
2012 RGC Vivid Black,Drago's True Duals&Mufflers, PC5,& Zipper's A/F.Monotubes -1 & 944-4002, Wild One Outlaw 12", Daymaker & Hawg Wired 6 Pack with Tweeters.
01-10-2013, 04:51 PM
As mentioned before . Using the existing battery tender plug is the easiest route,
[/SIGPIC]  [SIGPIC]
01-10-2013, 05:38 PM
Cool. Thanks to all so far.
02-01-2013, 06:05 PM
Site Sponsor
I installed power plug in my left glove box drilled out the plastic with a unibit to size then wired directly to the cig. lighter works greart to charge small electronics or power my GPS
