Neck bearing adjustment - Page 2 - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > The Glide Tech Area
The Glide Tech Area For Tutorials and Instructional Materials
Old 11-21-2012, 10:47 AM
cloud's Avatar
cloud cloud is offline
Originally Posted by EdY39 View Post
Zerk fittings are threaded. Replace with a 90 degree fittings or get a connection that slides on from the side. I've used "Green grease" for years in the fork stem. Good stuff and no drips in hot weather.
Thanks Ed, I have tried the grease connection that slides on from the side......works very poorly. If they are threaded I will go that route before I cut the fairing bracket any. I am going to check on that "green grease"
Thanks again
Cut N Shoot Hog Chapter, Patriot Guard Rider
'05 FLTRI, Stage 1 setup and gear driven cams installed.
'12 FLTRU, Stage 1.
Old 12-01-2012, 09:02 PM
96349 96349 is offline
I changed to a 12" long rubber hose on my grease gun. It works very well. cost about $10.00 I think.
Old 01-14-2013, 12:24 PM
BoeCole BoeCole is offline
If you do not have any front end shimmy between 40 - 50 on decelleration, why bother unless things are really loose. As to grease fittings, get a 90 degree job - makes life much easier.
BTW - I use a good quality marine grease as its water proof and does not seem to melt away on hot days.
Old 02-17-2013, 10:35 PM
ExtremeLimitz's Avatar
ExtremeLimitz ExtremeLimitz is offline
Originally Posted by skratch View Post
before you go to all this trouble, do the fallaway check. if it is within spec. don't mess with it. and just in case your manual still has the old specs, it has been changed to 1.5 to 3 swings (i think thats what it is, mine is on the tight side at 2)
What is a swing u refer to? I have never had to adjust the neck bearings befor on a factory set up bike.
Old 02-17-2013, 10:37 PM
Forgot to subscribe.
Old 02-17-2013, 10:55 PM
laxinharley's Avatar
laxinharley laxinharley is online now
Put it on a lift, so the handlebars can swing freely. You may have to remove the clutch if its tight. Crank the bars all the way left or right and let them go. It should swing all the way right, left and settle straight. If it keeps swinging, mine was 5, than you need to tighten the bearing.
Old 02-22-2013, 11:31 AM
Wild Bill Coady's Avatar
Wild Bill Coady Wild Bill Coady is online now
Mine came from the factory with a wobble, not uncommon since its the same setup as the EG which allows for a 3 swing since the faring is mounted the the forks. At least thats how the service manager rationalized the factory error???
RUBBER SIDE DOWN . . . the other way just hurts!
2011 Road Glide Ultra
2003 Electra Glide Classic (RIP 9/3/11)
1987 XLH 1100 30th Anniversary
