I've searched until I'm blind, but I can't find anything indicating how to connect the HK head unit to the RF amp. I would like to use the pre-out inputs that came with the amp, but it's not a requirement. I saw where one of the aftermarket companies make a connector that plugs in the back of the HK unit, but does it have pre-out plugs or would I still have to cut/splice?
Also, on the PBR300X2, did you run power all the way from the battery to the amp? I see that the specs for power only indicate a 10 ga wire is required.
All assistance is appreciated!
