Bike wont start - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Troubleshooting for Road Glides
Troubleshooting for Road Glides List your Road Glide problems here, and DR. Ruth will answer them.
Old 12-26-2013, 08:56 PM
Bluchevypick's Avatar
Bluchevypick Bluchevypick is offline
Shark of the Month December 2013
Default Bike wont start
Well i need help. lol I went out to start my bike after it was under the cover for a few days on the tender and it wouldnt start. It was kicking back and spitting out the breather so i kept trying to start it with no luck. Then i came back later the day and got nothing. The bike has a Stage 4 HD kit with Woods 777 cams and a Thundermax tuner on it.
Fast forward to today. I went out there to try to start it with no luck. So, i hooked up my computer to it and pulled the codes for it. These are the codes im getting:
641 5v Vref1 out of range
2138 TGS Correlation Error
122 TPS1 Lo
2135 TPS Correlation Error
2101 TAC Actuation Error
2176 TAC Closed pos
2105 EFI Forced Engine shutdown
1511 EFI power management
1512 EFI forced idle mode
I di however plug my stock throttle body in and try to start it while twisting the throttle and the blade wont move so im thinking its not my throttle body but i may be wrong. The twist grip sensor got replaced by my stealer about a month ago. Do you think its the sensor or the Thundermax?
2012 RGU, Custom paint, stage 4 w/woods 777 cams, bassani road rage, CM Legacy ES 21/18 combo, 1 PBR amp and 1 RS-400 with 6 ZX series 6.5 speakers and a whole lot more.
Old 12-26-2013, 09:41 PM
dbell66253's Avatar
dbell66253 dbell66253 is offline
Did you try disconnecting the TMAX, putting some dielectric grease in the contacts, then resetting it and starting over again?
Sent from my SPH-L710
2010 FLTRX, Custom paint, 107 CI, TS Bags, CM Fury 21" Wheel, too many other extra's to list.
  #3
Old 12-26-2013, 09:42 PM
No i havent but i will try that first thing in the morning along with dielectric grease on the throttle body plug.
  #4
Old 12-26-2013, 09:45 PM
dbell66253's Avatar
Do both...... I've been there before. If that doesn't work Zippers support should be able to help. Do you by any chance still have your original ECM?
  #5
Old 12-26-2013, 09:47 PM
I do have my stock one but its not setup for the stage 4. I also dont know if i still have my stock o2 sensors
  #6
Old 12-26-2013, 09:54 PM
dbell66253's Avatar
Its not set for your bike, but in worse case scenario you can see if your bike will start with it to help you determine if the TB or TMAX is your problem.
  #7
Old 12-26-2013, 09:55 PM
Im guessing it will still start without oxygen sensors plugged up? Ill try the dielectric grease first
  #8
Old 12-26-2013, 09:57 PM
dbell66253's Avatar
If the bike will start with the original ECM then look to the TMAX for the problem, if not look at the TB. You don't have to hook up the O2 sensor, you'll just be testing, not going anywhere.
  #9
Old 12-26-2013, 10:00 PM
Alright. Ill do all this in the morning and let ya know what happens. Thanks
  #10
Old 12-27-2013, 09:50 AM
Big_gary's Avatar
Big_gary Big_gary is online now
Hopefully it's something simple.
10 FLTRX , Stage 1, 13" Madstad, Mono tubes, Heritage style bars
If I have to explain ,you wouldn't under stand anyway.
