cycle-rama 575 or woods tw-777 - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Engine Related
Engine Related Engine Builds and more for Road Glides
Sponsored by Drago's Bike Works
Old 10-12-2011, 08:00 PM
hognit hognit is offline
Default cycle-rama 575 or woods tw-777
Which would be a better performance fit for a 96" motor? With a stage 1, 2-1 exhaust. And can't seem to find a price on the cr575
Old 10-12-2011, 08:29 PM
easyrider9809's Avatar
easyrider9809 easyrider9809 is online now
Cycle Rama website is saying $360.00 for the 575's
  #3
Old 10-12-2011, 11:55 PM
CVO110 CVO110 is offline
CR575 works very well in 96" bike.
Standard base circle on this cam, so you can re-used the stock pushrods and lifters. Saves you a few $$$
Don't know if anyone has installed the new Woods 777 cam.
Give Wes a call at Cycle-Rama he is a great guy and will give you a lot of useful information.
  #4
Old 10-13-2011, 07:00 AM
tj316's Avatar
tj316 tj316 is offline
call Wes the CR-575 is a great cam
2011 FLTRX 103 Power Pak , T man 600 cams , Baisley Heads , Zipper's air cleaner, TTS tuner , Dragula pipe , Hawg Wired amp/speakers/tweeter grills , custom Mustang Seat, LRS 12" , HID Head Lights , Dakota Digital Gauges , BR 1 1/2" Sweeping Beater Bars , True Track Stabilizer, Ohlins shocks / Ohlins forks, Jagg Fan Assisted 10 row oil cooler & so much more TJ Sunny Florida
  #5
Old 10-21-2011, 02:16 AM
Garcou Garcou is offline
Ahhh hell just build the motor and throw the 590's in
Shane (From Washington)
2010 Road Glide Custom
Axtell 107 (10.6-1 Compression), Pro Street Heads by Dewey, TMAN 590 cams, S&S Roller Rockers, Woods Directional Lifters, Revolution Performance EMS, D&D Boss Fatcat, HD Heavy Breather, Alpine IDA-305s head unit, Boston Acoustic Pro 60SE Speakers, Alpine PDX 2.150 Amp. 116 HP/128 TQ
Various chrome and black bits......
"I've Got A Cobra Snake As A Necktie"
  #6
Old 11-01-2011, 01:41 PM
John Harper John Harper is offline
Hey CVO110,
I got a quote from WES, and he sent me one saying that i need new pushrods because of the base circle being smaller than stock, and also for lifters as well???? Is that maybe a canned response, and I WON'T need all of that stuff???? He also sent me a dyno chart that is exciting!!!! up 16 Ft/lbs. and 10 HP That is H U G E.... It all will cost about a grand, but I'm thinking it's worth it. It will be cheaper though if you are correct, and i can use my pushrods and lifters.... If you have actually done this in a 96" let me know, and i'll just order the cams....
  #7
Old 11-01-2011, 02:13 PM
jeff jeff is offline
if the base circles are indeed smaller which I have read they are then you need adjustable pushrods. seems like being Wes designed the cams I would take his advice lol.
  #8
Old 11-01-2011, 07:40 PM
CR575 Specs:
Intake 15/35 .575Lift 230Dur 100LC
Exhaust 49/07 .560 Lift 236Dur 111LC
OVLP 22
TDC .156 Intake .109 Exhaust
Base circle dimension of this cam-.020 or .630 Radius.
Stock being .650 Radius.
Your stock pushrods will be fine.
  #9
Old 11-02-2011, 08:15 AM
CR575 Specs:
OVLP 22
I'm confused... the .020" difference is cool??? This cam would bolt in???
  #10
Old 11-02-2011, 03:00 PM
Yes Bolt in.
The base circle is 0.020 smaller than stock, then the mathematical preload
would be .090. Only one half of the base circle diffference. In which case, the stock PRs would work.
