10-26-2011, 09:38 AM
Valvetrain rattle in 2011 Roadglide Custom
Hello everyone, I recently purchased a 2011 Roadglide Custom. I am really loving it. It is amazing that a bike this big can handle this well.
The only issue i am having is some valvetrain noise, it rattles at all speeds but is most noticeable at 2200rpm. I mentioned it to the dealer and was told that some TC motors had more noise than others, that this was normal and that there was no valvetrain adjustment because of the hydraulic valvetrain.
This sounds like BS to me. I have built a few car engines in the past and even with hydraulic valvetrain there is still valve adjustment.
The bike has almost 1000 miles on it and I have been waiting until the first service to make them address this.
I have ridden a couple of other harleys recently (an 2010 with 10K on it and a 2012 with 500miles )and neither of them have any noise.
have any of you had this issue and was the dealer able to fix it?
10-26-2011, 09:49 AM
I have the same valve train noise @22-2300rpm (2011 RGU 103)
Jim
09 CVO rear, Ricor intiminators, Ohlins 3-3, Blade wheels, Corbin Solo, KW 1 1/4" heritage bars, Zumo 665, Chopped TP,255se cams, Bub 7's, Touring Duals, PCV
2011 RGU
10-26-2011, 10:07 AM
They're all noisy to some extent, some worse than others. There's been ump-teen gazillion "cures", new lifters, new pushrods, rocker arm supports, rocker arm shims, cams, oil pumps, thicker oil, thinner oil, etc, you name it, it's been claimed to be the cure, damn few of them do anything.
My '11 103" RGU is way quieter than my '01 95" Ultra Classic was
No, there is no adjustment in the stock valvetrain.
10-26-2011, 12:07 PM
Wow, You would think Harley would have more consistency in the mfg. My last HD was silent, my buddys 09 RG is silent and my other buddys 12 RG is silent. This tells me that it doesnt have to be like this.
Thanks for all the opinions and info guys.
10-26-2011, 12:23 PM
valve train noise
That may be what I have. Only rattles since I had cams installed. Does it at 2200 rpm anytime I accelerate. Rattel quits at about 2500.
2010 FLTRX Vivid Black.ABS-Security-Cruise
SE Pro Super Tuner, D&D Fat Cat 2-1 S&S 510 Cams
87hp 101tq
Contrast Chrome Agitators 19/18
Baggershield
Harley Hammock-Adj.Back Rest
King Tour Pac-Air Wing Rack(black)-Smoked LED-4 Pt.Dock-Black Latches & Hinges
Custom Dynamics LED's & Plazma Rods smoked front & rear with Magic Strobe
J&M 250w Fairing + Lower Rokkers
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
Kuryakyn Passenger detach. ArmRest & adj. pegs
10-26-2011, 02:46 PM
Gut your cat and take the stuffing out of your Rush pipes, then the noise will go away. Problem solved....
10-26-2011, 04:15 PM
Nobody should listen to anything this guy says, he's a crack head.
10-26-2011, 10:29 PM
I have valve train noise, but not really a ticking. Noticed it after I put lowers, deflectors and a taller windshield on. It seems normal.
10-27-2011, 03:21 PM
Your just jealous that my 103 is quiet.
| Thread Tools |
| Display Modes |
Linear Mode
