Issues with P2318 and P1510 Codes - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Controls & Handlebars
Controls & Handlebars Controls and Handlebars for Road Glides
Old 11-21-2011, 07:30 PM
Ruckus Ruckus is offline
Angry Issues with P2318 and P1510 Codes
Anyone else out there that had these codes when they put new bars on? I ran with the extended TBW from Harley so I wouldn't have t o slice and dice, but now these codes are coming up. Any help or suggestions? I can't be the only one out there.
THANKS!
Old 11-21-2011, 07:35 PM
mroach mroach is offline
code-P1510 = EFI Limited Performance Mode
There are two position sensors in the twist grip. one reads 0V at full throttle and 5V at closed throttle and the other reads 5V at full throttle and 0V at closed.
If the volts coming back from the 2 sensors dont add to 5V, or one sensor gives a voltage that doesnt make sense, then it raises the code.
You might have a loose wire in the TGS green connector in the bars.
I had that code on mine and looked it up, replugged the connectors and that sorted it out.
i suspect the other code would be tgs related as well but do not know what it means for sure
2011 Road Glide Ultra
72 Shovel
68 shovel 40 over denvers....
84 ZL900
2009 Busa
  #3
Old 11-21-2011, 07:52 PM
Is it possible that I have the red's white's and black's reversed in the TBW that plugs in to the larger duetche in the fairing?
  #4
Old 11-22-2011, 08:39 AM
Yes, check the colors in the manual or online in relationship to the plug
72 Shovel
84 ZL900
2009 Busa
  #5
Old 11-22-2011, 10:30 AM
HD_Shock's Avatar
HD_Shock HD_Shock is offline
Not sure about the extended TBW HD setup but the stock TBW has TWO sets of wires of the same color. Make sure you didn't get those reversed.
You can look up code meaning in the troubleshooting section.
-phil
2011 FLTRX 103
VH Dresser Duals | Klock Werks SS | HD Ventilator | Power Vision | Santees 11in Apes | CB SSC Euro 15in
  #6
Old 11-22-2011, 05:07 PM
Thanks Phil- it's the same set up as the stock one, just extended in to the fairing.. Only problem is the don't give you a wiring diagram to go with the new plug.. Kind of a guessing game I guess.
Thanks!!
Tags
new bars- throwing codes
Insurance
Please select your insurance company (Optional)
