Activating Rear Speakers in the HK Head - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Audio
Old 12-10-2011, 12:23 PM
Shrug's Avatar
Shrug Shrug is offline
Send a message via Yahoo to Shrug
Default Activating Rear Speakers in the HK Head
Ok HD audio experts...
I want to take my old HogTunes Amp and install it in my Tour Pak wired to the HogTunes speakers installed there. I'll extend power back there to a combined power/speaker plug and make the entire system detachable and then follow that up with the Boom Audio bass ports, but for now, I have a few questions:
  1. What's involved in activating the rear speakers on a stock HK head? Do I need to take it to the dealer?
  2. When the rears are activated, is any front/rear fader control available from the handlebar controls?
  3. Can anyone tell me from which harness connector ports I would extend wiring to the rear pods?
  4. Can the rear speaker lines be connected to the harness without dealer intervention providing rear audio, but without front/rear fader control?
  5. I'm considering having Iron Cross Audio install line level inputs for my Arc amp and change out the display to match my blue gauges. Does anyone know if they can activate the rear speakers?
Any insight appreciated!
Shrug - Scott Wilson
2010 FLTRX "Hester" -
Blue Knights Texas Chapter XLVI
Old 12-10-2011, 12:42 PM
Shrug's Avatar
Originally Posted by Shrug View Post
  1. I'm considering having Iron Cross Audio install line level inputs for my Arc amp and change out the display to match my blue gauges. Does anyone know if they can activate the rear speakers?
Iron Cross already answered my email. They say they will activate the rear at no charge with the other work I'm having done there. Cool!
  #3
Old 12-12-2011, 12:10 PM
JJSW1283's Avatar
JJSW1283 JJSW1283 is offline
Looks like youve got it covered, but I'll throw in my .02 I have hogtunes also, the amp I got from them takes the front 2 channels and splits it into 4, so I didnt have to mess w/ the HK.
2011 FLTRX Black Demin 103, 21" CM Raider, -2 progressive monotubes, DIY air ride, WO 14" black apes, Power Vision, RSD Venturi, Dragula 2into1, Mean Mug bezel, Corbin solo
  #4
Old 12-12-2011, 01:29 PM
Shrug's Avatar
Thanks JJ.
I had the HogTunes installed the way you described and there was no independent front/rear volume control. I yanked it when I installed the Arc amp and Hertz speakers. Since it's laying around and since I'm sending my HK head in to Iron Cross anyway, I figured I'd rig it up in the Tour Pak.
  #5
Old 12-12-2011, 01:41 PM
JJSW1283's Avatar
Yeh sometimes I wish I had the fader controls. It could probably still work if I got the HK program then run the amp in 4ch mode instead of 2ch
  #6
Old 12-12-2011, 02:04 PM
Shrug's Avatar
I'm doing it primarily because I can for free. ICR is activating the rear speakers at no additional cost. All I need to do is extend the speaker wires from the HK harness and run power to the Tour Pak through the same detachable plug.
I still need to know which HK harness plug and wires if anyone reading this thread knows.
  #7
Old 12-12-2011, 03:46 PM
Vettster's Avatar
Vettster Vettster is offline
I still need to know which HK harness plug and wires if anyone reading this thread knows.[/B][/QUOTE]
Shrug,
I think (IIRC) that I had to install the HD accessory harness to run the rear speakers.
It's the one from HD that also allows you to run the rest of the HK accessories like gps, intercom etc.
I will try to find the part number for you.
Here it is: http://www.harley-davidson.com/gma/g...bmLocale=en_US
Boom!™ Audio System Wiring Harnesses
Allow installation of Audio components on Ultra models.
70169-06A
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Allows installation of Bike-to-Bike Communications, Intercom, XM Satellite Radio Kit or Rear Speaker components.
Fits '06-later FLHT, FLHX, FLHTC, FLTR, FLTRX and FLHXXX models equipped with Advanced Audio Radio.
MSRP US $109.95
Ride Safe,
Vettster
  #8
Old 12-12-2011, 03:57 PM
DED HD's Avatar
DED HD DED HD is offline
Not sure what set up he has, but SINCECRAZY has an amp and tour pack all made detachable. Might PM him for some info.
'10 Red Custom:
check out my build thread for pix and mods http://www.roadglide.org/showthread....t=GR8FLH+Build
  #9
Old 12-12-2011, 10:54 PM
neversatisfied neversatisfied is offline
So does the dealer have to activate the rear speakers or will buying the wiring adapter be all that is needed?
  #10
Old 12-13-2011, 02:25 PM
zeus33 zeus33 is offline
ahhh this is a good thread and exactly what I want to do. I wouldn't be happy with the fairing speakers and saddle bag lid speakers on the same volume control.
Shrug, why are you sending your HK unit to ICR?? Is is malfunctining?
I'd like to activate mine as well, but don't have any other reason to send it to them. It would be nice to know how to do it ourselves.
