Ignition Question - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Engine Related
Engine Related Engine Builds and more for Road Glides
Sponsored by Drago's Bike Works
Old 01-23-2012, 01:52 PM
BlackDangerous's Avatar
BlackDangerous BlackDangerous is offline
Default Ignition Question
I am building a fairy stout 98" engine for my Glide. I have been looking into the Daytona Twin Tech ignition but I do not want to spend the amount of money that they are asking for them. Is changing the ignition a "MUST DO" or can I get by with the factory ignition?
Old 01-23-2012, 03:17 PM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
Engine Expert
Help us understand what kind of build.....
FD
A LEADER IN SUPER CHARGER / TURBO
PRO-CHARGER--TRASK TURBO--DBW DRAGULA 2;1 EXHAUST--DBW SUPERCHARGE SERIES EXHAUST--RUSH EXHAUST--HAWG WIRED--AIM CLUTCH--FEULING--POWER COMMANDER--THUNDER MAX--TTS MASTERTUNE--95" 135"ENGINE BUILDS & KITS--CNC HEAD WORK- DBW CRANK WORK-- DARKHORSE CRANK WORK--REVOLUTION PERFROMANCE--TMAN CAMS--DYNO TUNING-- BUILDS FROM 75 HP TO 600 HP
New logo by Chainsaw Graphics.
Drago's Bike Works 815-765-1790
www.dragosbikeworks.com
  #3
Old 01-23-2012, 07:27 PM
98"
Red Shift .557 cams
Good Street Head Port with Bigger valves
New Bearings (Cam)
40mm CV carb
About 9.3:1 Corrected compression
  #4
Old 01-23-2012, 07:30 PM
FGOWI FGOWI is offline
I'd call that more than "Fairy Stout".
Sorry, Bro.
  #5
Old 01-23-2012, 07:37 PM
First time going this far into my Glide. It should give me over 100/100, but the torque is what I am shooting for the most.
  #6
Old 01-23-2012, 09:11 PM
jeff jeff is offline
no way to tell but the stock ecm has a fairly aggressive timing curve on 88" baggers. Not sure what year yours is but if it is a carb and you are going 98" it must be a pre 07. My 04 95" egc that had mild head work and mild cam needed a dtt adjustable ignition for optimum performance.
  #7
Old 01-23-2012, 09:48 PM
Yep, my Glide is an 01 so it has the carb. I was able to lock the price down pretty good for the ignition. Do you think that $200 is a bad price for brand spaken new ignition?
  #8
Old 01-23-2012, 10:08 PM
what brand? if it is a daytona twin tech that is a good price. I paid something like $225 in 2005 or so. You will then need the software and cables to give it a custon map unless it runs good with the standard dial settings. DTT and headquarters are the same unit as I believe crane is as well. S&S made a neat one back then that had a knock sensor that it would autmatically adjust the timing. i think it was called IST or something like that but it was kind of spendy.
  #9
Old 01-23-2012, 10:16 PM
Yes it is a Daytona Twin Tech ignition. I am trying to get what it is that I need as cheep as I can as I want to buy a set of pipes from Drago. A friend of mine has a really cool toy from DTT. It is to measure the AFR. I think that I am going to relieve him of that item.
  #10
Old 01-24-2012, 08:55 AM
Engine Expert
Daytona makes nice stuff I would reccccc. more control you have the better tuning you can have. We are a dealer for them if you have any questions calls or them.
Insurance
Please select your insurance company (Optional)
