T-Man Cams - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Engine Related
Engine Related Engine Builds and more for Road Glides
Old 01-26-2012, 12:51 PM
FreeBird FreeBird is offline
Default T-Man Cams
Has anyone used the T-Man 555 or 555 Torqster cams? I have a stock 2008 96" that I would like to add cams to. I'm going to leave the motor stock except for Rinehart slipons, a breather kit, and a tuner.
2012 Road Glide Custom, Vivid Black.
Old 01-26-2012, 03:40 PM
1BigGuy's Avatar
1BigGuy 1BigGuy is offline
I've got the TM555 torqster in my 2010 FLTRX with a 96. It does give more seat of the pants torque and HP, but I've never had it on the dyno to see what it actual did. I like the extra feeling of power. Come to Kernersville and talk to him, that's what I did, his shop is over behind Lowes Foods just off of North Main.
full info:
96"
Harley Ventelator
Fuel moto 2 into 1 headpipe
Harley SE night stick
V&H Throttlepak
Power Commander V
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
Old 01-26-2012, 07:06 PM
Thanks Big Guy. I spoke to him on the phone and he recommended the torqstet. I wanted to go with the Andrews 48H, but T-Man will only dyno a bike that uses his parts.
Old 01-26-2012, 07:15 PM
jeff jeff is online now
every torqster dyno chart I ahve seen looks very good power down low and good hp too boot. it is on my short list.
Old 01-26-2012, 07:21 PM
How do you think the 555 Torqster compares to the T-Man 555's Jeff?
Old 01-26-2012, 07:31 PM
I think on a stock bagger the torqster is the only way I would go especially on a 96" but mine is a 103" and still the torqster is what I most likely will go with. there is a dyno section on htt (harley tech talk) that has a few of them.
Old 01-26-2012, 07:35 PM
Thanks Jeff. I'll check out that dyno site.
Old 01-27-2012, 08:10 AM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
Engine Expert
We sell and install many Tman 555
The 555tq is a nice pulling cam I call it truck cam for pulling. It pulls real nice up to 3800 rpm tq right there. It likes stock 9.3 or 10.1 max for compression.
The 555 Std is a nice over all cam pulls real nice all the way up and you can run 9.5 to 10.8 comp and it loves up.
My self and Red Rock HD have seen this cam make on 103" and 107" 116 hp and 120/128 tq.
But the TQ one does make more down low power faster than the std 555 but the std makes more mid and top end and carrys the tq curve longer across the rpm range.
Either one you pick you will enjoy....
One of are dealers thats (Tom at Deklab Equipment in Sycamore ILL).Sells are products bought a 525 tman and Dragula 2:1 with pvc and tuned at Workmans HD on a 09 96 inch motor made 93hp 103 tq. Not bad for a little cam..
And the 525 and 555 std are the same but the lift is a little more on the 555.
Any questions TR or myself would be more than happy to help.
FD.
A LEADER IN SUPER CHARGER / TURBO
PRO-CHARGER--TRASK TURBO--DBW DRAGULA 2;1 EXHAUST--DBW SUPERCHARGE SERIES EXHAUST--RUSH EXHAUST--HAWG WIRED--AIM CLUTCH--FEULING--POWER COMMANDER--THUNDER MAX--TTS MASTERTUNE--95" 135"ENGINE BUILDS & KITS--CNC HEAD WORK- DBW CRANK WORK-- DARKHORSE CRANK WORK--REVOLUTION PERFROMANCE--TMAN CAMS--DYNO TUNING-- BUILDS FROM 75 HP TO 600 HP
New logo by Chainsaw Graphics.
Drago's Bike Works 815-765-1790
www.dragosbikeworks.com
Old 01-27-2012, 10:25 AM
FD,
Based on your response, It sounds like the 555 will be a better cam for me. I'm also going to change my final drive ratio via a 30T Andrews trans pulley. We have a cross country tripped planned to Montana this year that will include extended periods of 80 mph riding, as well as slow curvy mountain riding. Thanks a lot for your help.
