CVO 110 Performance Upgrade - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Engine Related
Engine Related Engine Builds and more for Road Glides
Sponsored by Drago's Bike Works
Old 02-07-2012, 08:25 PM
smitty2u's Avatar
smitty2u smitty2u is offline
Default CVO 110 Performance Upgrade
This is my first post to the general forum. I have a 2011 FLTRUSE which I initially just want to do pipes, slipons, tuner, and a good Dyno. It seems for me, that scooter projects always morph and this was no exception. What started as a slight modification has turned out to be something quite different. Here's the build that's underway:
Head sent off to be done by T-Mann, his Pro Touring Version
T-Mann 625 Cam
SE 10.5:1 forged pistons
4-5/8" stroke Se Pro Stroker Flywheel and rod Assembly, balanced and welded by Revolution Performance
Timekin Bearing
SE 58mm TB
SE 5.3 grms/sec injectors
SE Pro tuner.
Woods lifters,
SE rods
SE Clutch upgrade
Andrews 31T sprocket
V&H Power Dual headers and V&H 4" Monster Round mufflers.
Staying with the stock breather cover, but switching to a K&N filter.
Last but not least, would be a good Dyno.
My scooter has been at my local dealer, (Buckminns in Xenia Ohio) for a couple weeks. Heads are due back this week and then reassembly begins.
If anyone is interested I'll post the Dyno results when she's finished.
Smitty
Old 02-07-2012, 09:02 PM
FLTR2008Trike's Avatar
FLTR2008Trike FLTR2008Trike is offline
I had TR @ Tman do his quality work to help me build my 117" 2 years ago. Hes very meticulous about his work and his shop is spotless. You will be very happy with your results
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @http://www.jwperf.com/ . 10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
  #3
Old 02-07-2012, 09:04 PM
connector's Avatar
connector connector is online now
Wow that really Morphed on you I like the idea though .Do it once ,do it right . I'm curios as to how this set up works for you , just changing out my cam ( T-Man 590 ) so post up your results..This should be good
09 FLTR 103 Stage III
J Prescion Heads \ 10.5:1 \ T-Man 590 cam \ ThunderMax tuner \ Feuling cam plate and tensioners \ Jaggs cooler \ Progressive front end \ Dragos SC series pipe \ Top Shop Bags \ Yaffe 10 inch bars\ Hawg Wired ZX and RF inner fairing speakers 500 Watts and Lots more
  #4
Old 02-08-2012, 05:17 AM
DreamRider's Avatar
DreamRider DreamRider is offline
Look forward to seeing the outcome. Maybe post some pics of before and after
DreamRider
RoadGlide FLTR 09' - Vivid Black -
Dreaming about the next LONG ride
Shark Week V Texas --> June 15th through June 19th, 2015 LINK
Previous Shark Week Photos Threads : SWI 2011 LINK & SWII 2012 LINK
  #5
Old 02-08-2012, 07:01 AM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
Engine Expert
You will have a nice build there you will be happy... Cant wait to see.
Originally Posted by smitty2u View Post
This is my first post to the general forum. I have a 2011 FLTRUSE which I initially just want to do pipes, slipons, tuner, and a good Dyno. It seems for me, that scooter projects always morph once their started and this was no exception. What was started as a slight modification has turned out to be something quite different. Here's the build that's underway:
Head sent of to be done by T-Mann, his Pro Touring Version
T-Mann 625 Cam
Timekin Bearing
SE 58mm TB
SE Pro tuner.
Woods lifters,
SE rods
SE Clutch upgrade
V&H Power Dual headers and V&H 4" Monster Round mufflers.Staying with the stock breather cover, but switching to a K&N filter.
Smitty
A LEADER IN SUPER CHARGER / TURBO
PRO-CHARGER--TRASK TURBO--DBW DRAGULA 2;1 EXHAUST--DBW SUPERCHARGE SERIES EXHAUST--RUSH EXHAUST--HAWG WIRED--AIM CLUTCH--FEULING--POWER COMMANDER--THUNDER MAX--TTS MASTERTUNE--95" 135"ENGINE BUILDS & KITS--CNC HEAD WORK- DBW CRANK WORK-- DARKHORSE CRANK WORK--REVOLUTION PERFROMANCE--TMAN CAMS--DYNO TUNING-- BUILDS FROM 75 HP TO 600 HP
New logo by Chainsaw Graphics.
Drago's Bike Works 815-765-1790
www.dragosbikeworks.com
  #6
Old 02-08-2012, 08:29 AM
Rowdy's Avatar
Rowdy Rowdy is offline
Send a message via Yahoo to Rowdy
I'd say it morphed... I am subscribed, very interested in the numbers it produces.
Rowdy
Ridin a two lane montser, feedin on one cage at a time ...
  #7
Old 02-08-2012, 10:20 AM
smitty2u's Avatar
Here's a few pictures of the beginnings of the project. Will post more, probably next week.
Smitty
2011 FLTRUSE
124HP 130TQ
TR Stage 2 Street Eliminator Pro-Touring Heads
TR 660-SM Cam
TTS Master Tuner
Cylinders 4.060 Bore
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
V&H Power Dual headers with V&H Twin Slash Round Slipons
K&N air filter
Andrews 31T transmission sprocket
  #8
Old 02-08-2012, 03:22 PM
smitty2u's Avatar
The "Do it once" idea is how this all evolved. I didn't want to have to pay twice for labor and another dyno. I figured it was cheaper in the long run to build it the way I wanted it, the first time.
Smitty
2011 FLTRUSE
124HP 130TQ
TR 660-SM Cam
TTS Master Tuner
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
K&N air filter
  #9
Old 02-17-2012, 06:58 PM
smitty2u's Avatar
Well the bottom is back together. We've changed a few things as well. Going with the TTS Mastertune, TR-660-SM cam, cylinder bored to 4.06.
Smitty
2011 FLTRUSE
124HP 130TQ
TR 660-SM Cam
TTS Master Tuner
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
K&N air filter
  #10
Old 02-17-2012, 06:59 PM
smitty2u's Avatar
Can't wait to hear her run.....
Smitty
2011 FLTRUSE
124HP 130TQ
TR 660-SM Cam
TTS Master Tuner
Timekin Bearing
SE 58mm TB
SE lifters,
SE rods
SE Clutch upgrade
K&N air filter
