Vance & Hines Stainless Hi-OutPut Duals for 2009-2012 Touring Baggers - Road Glide Forums
Go Back   Road Glide Forums > Roadglide.org Site Sponsors Forums > SlickCustoms
SlickCustoms Email Slick with questions or post here!
Old 03-21-2012, 12:19 AM
Slick Customs Slick Customs is offline
The Boss at Slick Customs
Default Vance & Hines Stainless Hi-OutPut Duals for 2009-2012 Touring Baggers
Resetting the bar for the most exclusive system available for the Touring segment, Stainless Hi-Output Duals bring together premium materials and high performance tuning for heavily modified motors with a bold race-inspired “works” finish.
Continually pushing the performance envelope, Stainless Hi-Output Duals, available for 2009-2012 Harley-Davidson Touring models, matches tapered head pipes with larger inlet mufflers.
Every aspect of Stainless Hi-Output Duals has been developed and tested through countless hours of dyno time with the singular focus to increase volumetric efficiency critical to extracting maximum horsepower from high output engine modifications.
- Engineered for High Output Engine Modifications
- All Stainless Steel Construction with TIG Welding
- Contoured Laser Cut Heat Shields
- Race-Inspired Brushed Stainless "Works" Finish
- 1.75-inch to 2-inch Tapered Head Pipes
- 2-inch Inlet on Mufflers
- 3-inch to 3.25-inch Baffle with Anti-Reversion Cone
- 4-inch to 4.5-inch Stepped Muffler Body
- Flat Plane 12mm & Quick Access 18mm Oxygen Sensor Ports for Wideband Tuning Capability
Old 07-19-2012, 12:56 PM
johnnyd's Avatar
johnnyd johnnyd is offline
I really wish I seen this set up before I bought the SE-Nightsticks...
  #3
Old 07-19-2012, 02:37 PM
Stick_FSMC's Avatar
Stick_FSMC Stick_FSMC is online now
Looks like the same setup I have, only in Stainless. I have the Power Duals with the Hi-Output in black.
I love the sound and performance. Major improvement over stock.
Stick
USAF 1980-84
2012 FLTRU
110cid w/V&H Power Duals/Hi-Output, HD Heavy Breather, HD Race Tuner, J&M Rokker Series Front/Rear w/500w amp
2005 VN2000
125cid w/V&H Powershots and PC III. 116+ hp, 140+ lbs/ft torque. FOR SALE
1962 XLCH
Full on Custom Chopper w/many one-off parts.
