Help - Front Caliper Pistons - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Troubleshooting for Road Glides
Troubleshooting for Road Glides List your Road Glide problems here, and DR. Ruth will answer them.
Old 04-30-2012, 07:32 AM
kbrown82 kbrown82 is offline
Default Help - Front Caliper Pistons
My front brake pads have started dragging to the point with the front wheel off the ground the tire does not have any free spin. It stops as soon as my hand releases the wheel. I was attempting to clean the calipers and push pistons back in caliper per instructions on a link posted elsehere on this forum. Problem is I can't get the right side caliper pistons to retract into the caliper. I am assuming they should be flush with the caliper. I have loosened screws on master cylinder and tried to use flathead screwdriver to retract pistons but they wont budge. Now I can barely get caliper back on rotor and when I tighten down bolts wheel wont turn at all. Any suggestions appreciated.
Ken
Old 04-30-2012, 05:24 PM
FrankieB's Avatar
FrankieB FrankieB is offline
Crack open the bleeder valve then use a big flat tip, with old pads still in it,and try and wedge them apart. If this don't work then it is time to rebuild the calipers.
06 RK
11 RGU
  #3
Old 04-30-2012, 05:32 PM
rlaf75's Avatar
rlaf75 rlaf75 is offline
+1. if the pistons do retract with the bleeders open then youll probably have to change the break hose
09 Mirage Orange Pearl
  #4
Old 04-30-2012, 09:08 PM
Thanks very much for the info. I will give it a try.
Ken
  #5
Old 05-01-2012, 09:10 AM
ironmark's Avatar
ironmark ironmark is offline
Did you try using a small c clamp? You should use the old brake pad and put this against the piston then use the clamp to put pressure on the piston to draw in the piston straight, using a screwdriver may push the brake caliper piston in crooked and bind it up not allowing the piston the retract properly.
08 FLTR candy red sunglo, 103 Stage II, Woods TW-222 cams, V&H Dresser Duals with Monster Rounds, Thundermax tuner, Willy Shiny Wheels and Forks and a bunch of other stuff.
  #6
Old 05-01-2012, 11:43 AM
Thanks for the tip. Will try a c-clamp
