Front brakes "squealing"? - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Troubleshooting for Road Glides
Troubleshooting for Road Glides List your Road Glide problems here, and DR. Ruth will answer them.
Old 05-15-2012, 02:34 PM
SGT_Rob SGT_Rob is offline
Default Front brakes "squealing"?
Hey all, just wrapped up my build last Thursday and I've noticed over the weekend that almost everytime I come to a stop I get a weird squeal the last second or so before I stop. Imagine a horror movie where someone opens a rusty door slowly. It's a sound similar to that. I know it didn't make that sound before. It's been nearly a year since the bike was rode, closer to 19 months since being used regularly. Anyways almost everytime I come to a stop I get this noise. There is no wobble and no noise at speed when braking. I have a 21" wheel from SMT machining and spacers from wily shiny. I was thinking maybe beatings aren't fully seated? They brakes and rotors touch very very slightly when on a jackstand. Any ideas?
2010 road glide custom dual rotor, non abs.
Factory brake pads with 3400 miles on them
SGT_Rob
The very essence of leadership is its purpose. And the purpose of leadership is to accomplish a task. That is what leadership does–and what it does is more important than what it is or how it works.
~Colonel Dandridge M. Malone
Old 05-15-2012, 02:53 PM
rlaf75's Avatar
rlaf75 rlaf75 is offline
Take the pads off and use a very fine grit sandpaper to LIGHTLY scuff the pad and make sure the pad to caliper contact points are lightly lubricated. Make sure the rotor is aslo clean.
09 Mirage Orange Pearl
  #3
Old 05-15-2012, 10:14 PM
you know I didn't even think of lubricating the pad to caliper contacts. The bike has been sitting for quite awhile. It definitely might need a bit of lubricant. What would you suggest using.
SGT_Rob
  #4
Old 05-15-2012, 10:47 PM
rlaf75's Avatar
At work i use a silicone brake lube from ACdelco. A small can of that is about $10 but works great. I would suggest going to your local autoparts store and see what they recommend for a brake lubricant. You will not need to apply much at all and keep it off the pad surface and rotors. That will only amplify the problem
  #5
Old 05-16-2012, 10:41 AM
I thought if I lubricated the pads and rotors it would double their life and be super quiet when I stop!!
SGT_Rob
  #6
Old 05-16-2012, 12:56 PM
HD_Shock's Avatar
HD_Shock HD_Shock is offline
You mean IF you stop! lol
-phil
2011 FLTRX 103
VH Dresser Duals | Klock Werks SS | HD Ventilator | Power Vision | Santees 11in Apes | CB SSC Euro 15in
  #7
Old 05-16-2012, 07:10 PM
rlaf75's Avatar
why would you want to stop?
  #8
Old 05-16-2012, 07:11 PM
Fat Tom's Avatar
Fat Tom Fat Tom is offline
I use a little silver grade never sieze on any contact points between pad and caliper, and never get a squeak.
2006 Road Glide
  #9
Old 05-17-2012, 12:38 AM
Dfwhockey17 Dfwhockey17 is offline
We use a disc brake quiet spray from Napa when we do pads at our shop to help keep things quiet....and it works very well....
Cheers,
Trent
