cold cranking amps ? - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Tech Area
Tech Area For Tutorials and Instructional Materials
Old 05-23-2012, 09:10 PM
mea4dxl's Avatar
mea4dxl mea4dxl is offline
Question cold cranking amps ?
Anyone know what is the cold cranking amps on the road glide batterys? I have a 2007 with the org battery in it.
REER = Ride to Eat Eat to Ride
2013 FLTRU, 2003 883R, 2003 Savage 650 Bobber
Old 05-23-2012, 11:19 PM
Dfwhockey17 Dfwhockey17 is offline
I don't know exactly, I know the batteries are made by Delka and would hazard a guess they are somewhere in the 375-400 range....Why do you ask?
  #3
Old 05-23-2012, 11:33 PM
mea4dxl's Avatar
I did a load test and it shows it in the green. It also show that its only 200 cold cranks. to me thats kind of low.
It wont start as fast as I would like it to. The batt is 5 years old.
I need to stop being cheep and get a new one .
what do you think?
  #4
Old 05-23-2012, 11:38 PM
You definitely got your moneys worth out of it....Better to replace it when you can than have it leave you stranded somewhere...What is the Voltage? Then what is the Voltage when a load is applied to it?
  #5
Old 05-23-2012, 11:45 PM
mea4dxl's Avatar
not sure. I just checked to see if it was in the green or not. Im just going to replace it asap.
Anyone know a good web site that is cheeper then $170. with the shipping?
  #6
Old 05-23-2012, 11:54 PM
I sell them for $159 and could make you a deal, send me a pm with address and I will get the info in the morning.....Not sure how much shipping would cost you though, maybe around $15....
  #7
Old 05-24-2012, 08:35 AM
ironmark's Avatar
ironmark ironmark is offline
The batteries you get from HD are real good batteries so I would stick with it. You may pay a little less for a aftermarket battery but it may cost you in the long run. I replaced my battery on my 08 about 3 months ago, the original battery was still good but I just felt better having a new battery in the bike, but I am a preventive maintenance type of person. On a side note I had the nylon strap that is under the battery that assist in the battery removal break, the strap was dry rotted so I had to make a new strap, I used a heavier wider strap this time. The battery is a real PITA to get out without the strap.
08 FLTR candy red sunglo, 103 Stage II, Woods TW-222 cams, V&H Dresser Duals with Monster Rounds, Thundermax tuner, Willy Shiny Wheels and Forks and a bunch of other stuff.
  #8
Old 05-24-2012, 12:04 PM
Delka makes good batteries, but the Yuasa's are just as good and typically a few bucks cheaper. I like the fact that with the Yuasa I am the one who is getting to activate and charge the battery initially so I can make sure it is done properly...We have had too many factory activated batteries end up not holding a charge because they sat on a shelf forever and are no longer good, or were not properly activated. Regardless of what battery you choose, stay away from the Chinese batteries!!!!!
  #9
Old 05-24-2012, 12:35 PM
mea4dxl's Avatar
thanks for all your help. Im going to get a new batt from the dealership with a 10% hog discount and no shipping. Just seems easyer.
  #10
Old 05-24-2012, 01:05 PM
Yeah man, no worries....While you are at it you might consider installing battery tender leads so you can keep the battery topped off when you are not riding it...
Tags
cold cranking amps
Insurance
Please select your insurance company (Optional)
