Cam suggestions - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Engine Related
Engine Related Engine Builds and more for Road Glides
Sponsored by Drago's Bike Works
Old 08-09-2012, 05:44 PM
maddogdrury maddogdrury is offline
Default Cam suggestions
I have an 11 RGU with nightsticks, stage 1, de-chatted, Cobra Fi2000 tuner and am looking for cams, Ride 10-12k per year, Almost always 2up, 425lbs combined weight. Could be talked into pipes as I am not in love with nightsticks and not sure of the advantages of de-chatted vs true header. Looking for 40-70 mph power curve. Anyone have input.
1976 Kawasaki KZ900
86 road glide(cream n crap)
97 EG ultra(frank)
98 Heritage Springer(Bruiser)
03 EG Standard(Blackie)
2011 RGU Big Blue Pearl blacked out(Papa Smurf)
Old 08-09-2012, 06:04 PM
prodrag1320
Guest
Posts: n/a
if your doing a "cam only" change (ie:no compresssion or headwork)ide look @ the andrews 37
  #3
Old 08-09-2012, 11:41 PM
JacktheBagger's Avatar
JacktheBagger JacktheBagger is offline
S&S 551
JtB
2011 Ultra
  #4
Old 08-10-2012, 06:02 AM
Hillsidecycle.com Hillsidecycle.com is offline
Engine Expert
Send a message via AIM to Hillsidecycle.com
Wood 222.
You'll be AMAZED!!!
Scott
"Over 25 plus years of Harley-Davidson engine building, and cylinder head work."
Complete machine shop
Complete cylinder head shop
Dyno tuning
Extended Warranty Center
MMI Certified Mechanics
Stocking Dealer for;
S&S Cycle
Axtell Sales
Wood Performance
Horse Power Inc.
Andrews Products
Rivera Engineering
Bandit Machine Works
"Land Speed Record Power"
www.hillsidecycle.com
5225 South Main St.
Munnsville, N.Y. 13409
315-495-6650 phone/fax
M-F 8-5, Sat 8-12 or by appt.
  #5
Old 08-10-2012, 09:11 AM
tdkkart tdkkart is offline
I've got the SE204 in mine, works well. IMO 6th gear was useless at 60mph before, now it's quite useable, the bike will actually accelerate when you turn the throttle when cruising in 6th. Probably added 10mph of useable range to 6th gear, and added quite a bit of mid range pull when running through the gears. The intake closing number makes it drop a bit of cranking compression, which helps reduce pinging also.
I used the Andrews 37 in my 2 previous bikes, but wouldn't use it without bumping the compression up a bit first. The later(later than the 204) intake close drops a bit too much compression for a stock motor IMO.
I have no experience with the S&S or Woods cams, but the numbers on the 222 do look good.
2011 Merlot RGU, 103", SE204 cams, Fuelmoto E-series 2-1, Ness BS, Power Vision, Progressive 940s/Monotubes, 13" MadStad.
  #6
Old 08-10-2012, 12:19 PM
rgbikeman rgbikeman is offline
Smile
Scott, how do you like the new Woods TW-222 cam compared to the new Andrews 57H cam.
  #7
Old 08-10-2012, 12:50 PM
jeff jeff is offline
he said looking for 40-70mph increase with 425 lbs of weight. se255 or andrews 48 would fit the bill
  #8
Old 08-10-2012, 09:18 PM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
Engine Expert
There are so many good cams out there that fit the bill.
Tman 555 tq
Cycle rama 575
Andrews 57 new
S&S 551
Tman 600 sm
Woods 222 new
Zippers 525 cams new
But adding cams is like getting a tattoo you will want more.
All those cams up above will work. At my shop we favor Tman cams.
We have done builds for stock 103 tman 555tq with a good exhaust and tune and have seen 98 hp 110 tq.! With good port job we have seen 105/110 hp and 118/125 tq. With out building high compression motor. Just make sure you pick the right cam that can grow with your build.
FD......
A LEADER IN SUPER CHARGER / TURBO
PRO-CHARGER--TRASK TURBO--DBW DRAGULA 2;1 EXHAUST--DBW SUPERCHARGE SERIES EXHAUST--RUSH EXHAUST--HAWG WIRED--AIM CLUTCH--FEULING--POWER COMMANDER--THUNDER MAX--TTS MASTERTUNE--95" 135"ENGINE BUILDS & KITS--CNC HEAD WORK- DBW CRANK WORK-- DARKHORSE CRANK WORK--REVOLUTION PERFROMANCE--TMAN CAMS--DYNO TUNING-- BUILDS FROM 75 HP TO 600 HP
New logo by Chainsaw Graphics.
Drago's Bike Works 815-765-1790
www.dragosbikeworks.com
  #9
Old 08-13-2012, 06:30 AM
Engine Expert
Have not seen back/back comparisons as of yet.
Scott
Dyno tuning
S&S Cycle
Axtell Sales
Wood Performance
Horse Power Inc.
Andrews Products
Rivera Engineering
5225 South Main St.
  #10
Old 08-13-2012, 05:13 PM
RoadGlideGary's Avatar
RoadGlideGary RoadGlideGary is offline
Exclamation Cams
If you have extra $$$ buy the new designer cams, if you don't have the extra $$$ consider the tried and true - SE or Andrews. There is always something newer and hotter, so they say, but it it is reliability you want. Andrews makes a lot of cams under their name and for others - that should tell you something.
08' FLTR - customized !!!
05' SuperGlideCustom - sold
