FLTRX tail lights - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Lighting
Lighting Lighting for Road Gildes
Old 08-16-2012, 08:17 PM
mmcmsw's Avatar
mmcmsw mmcmsw is offline
Default FLTRX tail lights
Okay, On my 2011 RGC, I am trying to powder coat the rear tail light. I have the wires out, with the exception of the ground (black) wire still sitting in the reflector. I have been known to break stuff, so If there is an easy way to pull this connector out of the reflector, let me know. Thanks.
EDIT: I have looked at this, and I have two other options. Disassemble the deutcsh plug. (PIA) Cut, solder and heat shrink the wire harness.
Trailers are for Boats!!
Old 08-17-2012, 06:56 AM
mmcmsw's Avatar
Default any Ideas
any ideas???
  #3
Old 08-17-2012, 07:00 AM
dirt.bagger.11 dirt.bagger.11 is offline
i did cut and solder. i avoid solder if i can but it was the most direct option
  #4
Old 08-17-2012, 07:10 AM
HD_Shock's Avatar
HD_Shock HD_Shock is offline
Those ground wires were the same reason I cut and soldered. There might be another way but cutting seemed a whole lot easier than disassembling the deutcsh plug. I wanted the solder joints inside the housings but there's not much wire to work with ... I made the cut rougly 3/4 in. into the housings and soldered extensions onto the wires before I reassembled to give some room.
Here's where I made my cuts ...
-phil
2011 FLTRX 103
VH Dresser Duals | Klock Werks SS | HD Ventilator | Power Vision | Santees 11in Apes | CB SSC Euro 15in
