Battery Charging Problem 2012 - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Troubleshooting for Road Glides
Troubleshooting for Road Glides List your Road Glide problems here, and DR. Ruth will answer them.
Old 09-04-2012, 06:14 AM
Swampratt's Avatar
Swampratt Swampratt is offline
Default Battery Charging Problem 2012
Guy's, I was in a big hurry the other day and parked my bike inside my trailer (my storage) and jumped off the bike and left the ignition switch "on".....I know, what an idiot .....anyway, I come out in the morning and obviously its dead.
I charged the battery on 6amps for 5 hrs and I get nothing. I just charged it overnight(12hrs) on 4amps. It's now only showing a tiny bit of life (dash lights barley visable) Questions is: have I permanently damaged the battery by letting it go so dead and now it wont charge and need a new one?
I am using a Schumaker battery charger and maintainer
Thanks for any help
2012 FLTRX
Big Blue Pearl
Stage One
Traded: 2006 FLSTC
Old 09-04-2012, 07:36 AM
FrankieB's Avatar
FrankieB FrankieB is offline
Thanks for any help
I would try a different charger first, and make sure you have good contact on the bat. posts. Set the charger on two amp. You can put the charger on boost to start the bike, then take a long road trip, just don't turn the bike off until you are back home. Then load test it, that will tell you if bat. is messed up.
06 RK
11 RGU
  #3
Old 09-04-2012, 10:36 AM
chromedome's Avatar
chromedome chromedome is offline
The stock battery is an AGM type battery.
This might help you...
http://www.youtube.com/watch?v=Slqd73ZOQvI
2012 Road Glide Ultra / 2008 BMW R1200RT / 2002 Road King (sold)
  #4
Old 09-04-2012, 02:44 PM
Grapnel's Avatar
Grapnel Grapnel is offline
something like that happened to a friend, he had had to take it in and get a new voltage regulator, a stator, compinsator, and a battery.
it was all under warranty
  #5
Old 09-04-2012, 08:34 PM
Swampratt's Avatar
It sat on the charger all day today....still nothing. I will throw a multi-meter on it tomorrow at work and see what it has for voltage. I'm just really surprised that it wont charge.
Thanks for the help, hope I can get it squared away for the weekend!!
2012 FLTRX
Big Blue Pearl
Stage One
Traded: 2006 FLSTC
  #6
Old 09-04-2012, 08:56 PM
nightglide's Avatar
nightglide nightglide is offline
Good video Chromedome.
  #7
Old 09-04-2012, 09:24 PM
Frodoe Frodoe is offline
Heat is always an issue to take into consideration, if you have any time on it the heat might have ended an already existing issue.
  #8
Old 09-05-2012, 04:36 AM
FrankieB's Avatar
A multi meter won't tell you if you have a bad cell, it needs to be load tested.
06 RK
11 RGU
  #9
Old 09-05-2012, 08:09 PM
Swampratt's Avatar
I put it on a portable car charger for quick starts for 30 mins. Took it home and bam....started right up....Go figure
Thanks for help guys
2012 FLTRX
Big Blue Pearl
Stage One
Traded: 2006 FLSTC
  #10
Old 09-05-2012, 09:32 PM
FrankieB's Avatar
Sounds like the charger took a dump on you.
06 RK
11 RGU
