Popping exhaust - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Intake and Exhaust
Intake and Exhaust Intake and Exhaust Systems for Road Glides
Old 12-31-2012, 04:10 PM
justincollins's Avatar
justincollins justincollins is offline
Default Popping exhaust
After installing my slip ons I have noticed pretty bad decel popping from 2500 rpm up. I have the pc III and have the 0% side set as -20. Any suggestions. Thanks guys
2009 Red Hot Sunglo Glide
Stage 1
Cobra Slip-ons
Old 01-01-2013, 09:27 AM
stogieluvr60 stogieluvr60 is offline
Default Decel popping
When you replaced your mufflers, did you replace your muffler clamps as well? If not, you may well have an exhaust leak at the header/muffler junction. The OEM clamps stretch over time and though the became tight they may not be tightening enough. A common problem and an easy fix.
  #3
Old 01-02-2013, 06:45 AM
DragoBikeWorks's Avatar
DragoBikeWorks DragoBikeWorks is offline
Engine Expert
Shot me over an email with your specs and map I will help you out...
dragosbikeworks@yahoo.com
A LEADER IN SUPER CHARGER / TURBO
PRO-CHARGER--TRASK TURBO--DBW DRAGULA 2;1 EXHAUST--DBW SUPERCHARGE SERIES EXHAUST--RUSH EXHAUST--HAWG WIRED--AIM CLUTCH--FEULING--POWER COMMANDER--THUNDER MAX--TTS MASTERTUNE--95" 135"ENGINE BUILDS & KITS--CNC HEAD WORK- DBW CRANK WORK-- DARKHORSE CRANK WORK--REVOLUTION PERFROMANCE--TMAN CAMS--DYNO TUNING-- BUILDS FROM 75 HP TO 600 HP
New logo by Chainsaw Graphics.
Drago's Bike Works 815-765-1790
www.dragosbikeworks.com
