Maximum Oil Temperature? - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Engine Related
Engine Related Engine Builds and more for Road Glides
Sponsored by Drago's Bike Works
Old 04-17-2013, 06:48 AM
Swampratt's Avatar
Swampratt Swampratt is offline
Default Maximum Oil Temperature?
OK so I replaced my air temp gauge with an oil temp gauge over the winter, in some traffic and only 60*F outside, the oil temp gauge is reading up to 230*F until I get moving again, just curious how high the oil temp can get before it starts to breakdown or the motor can see damage?
I am running lowers but with the vents open, these will come off once the weather improves.
2012 FLTRX
Big Blue Pearl
Stage One
Traded: 2006 FLSTC
Old 04-17-2013, 07:07 AM
BART1 BART1 is offline
I installed a HD oil temp gauge on my 2007 RG (without lowers). It has had a HD oil cooler since it was new. My indicated oil temperature on the road indicates around 180 degrees and will increase to 220 - 230 degrees in city traffic on hot days when the bike sits in traffic. The temperature reading is taken from the coolest part of the oil pan, being in the front of the oil pan and in direct air flow. It appears the oil temp in the rear of the pan is 10 - 15 degrees warmer. I use Mobil 1 20w-50 V-Twin synthetic. I would feel safe if the oil temperature approached the 300 degree level, although it never comes close to that temperature. Petroleum base oils can approach the 250 degree range. These temperatures are based on the published oil specs. I live in southern Minnesota and the average temps are cooler than many parts of the country (especially this year!).
BART
  #3
Old 04-17-2013, 07:09 AM
tdkkart tdkkart is offline
Supposedly, 230 is the "design" temperature, and is indeed the temp that i see most often in normal open road type riding in normal temps of 70-80*, and it can take 20-30 miles to get there from a cold start. Obviously you will see highee temps in traffic and in higher outside temps. 250 is not terribly unusual. Todays synthetic oils can run to 300" pretty safely.
2011 Merlot RGU, 103", SE204 cams, V&H Dresser Duals, Ness BS, Power Vision, Progressive 940s/Monotubes, 13" MadStad.
  #4
Old 04-17-2013, 07:32 AM
Harleyagain's Avatar
Harleyagain Harleyagain is offline
See that is why I won't get a oil temp guage, I would be to distracted worrying abt how hot the oil gets. Ya I know it gets hot at Idle, it's a Harley!
Join us @ SWV. Hill Country, TX. June 15-19
Contact Myself, Triplej, or Andyman if you have any questions!
  #5
Old 04-17-2013, 07:33 AM
HellInABucket's Avatar
HellInABucket HellInABucket is online now
Confirming my thesis that you only worry about things for which you have gauges. Add a gauge, add a worry.
  #6
Old 04-17-2013, 07:45 AM
tmd tmd is offline
Your twinkie uses diesel grade oil. The dino versions are good to about 330* and the synthic is good for about 350*. The oil in your engine will never see either.
In 100*-110* summertime temps its perfectly normal for your engines oil to get upwards of 280*+. Don't panic, its designed that way. I always tell people that one of the worst things to get for their bike is an oil temp gauge because all you will do is stare at it and freak out everytime the temp gets higher then what you think it should.
I'm not saying this because I have over 30 years in the maintenance field.
I'm saying it because I slept in a Holliday Inn last night.
2011 RGU with more money then sence in it.
Oh and its black because blacks faster.
  #7
Old 04-17-2013, 08:37 AM
Zog's Avatar
Zog Zog is offline
Ain't that the truth.
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, bagger nation super stereo, jac-knife highway pegs, progressive monotubes, etc..etc..etc...
  #8
Old 04-17-2013, 11:13 AM
ironmark's Avatar
ironmark ironmark is offline
It was 95 degrees last Saturday when I was cruising across the desert doing 75 t0 80 mph on I40 and I saw oil temps up to 250. Mobil 1 20/50 V-Twin oil in my bike.
08 FLTR candy red sunglo, 103 Stage II, Woods TW-222 cams, V&H Dresser Duals with Monster Rounds, Thundermax tuner, Willy Shiny Wheels and Forks and a bunch of other stuff.
  #9
Old 04-17-2013, 12:13 PM
dbell66253's Avatar
dbell66253 dbell66253 is offline
"I'm not saying this because I have over 30 years in the maintenance field.
I'm saying it because I slept in a Holliday Inn last night."
That was pretty funny, thanks for the laugh tmd.
2010 FLTRX, Custom paint, 107 CI, TS Bags, CM Fury 21" Wheel, too many other extra's to list.
  #10
Old 04-17-2013, 12:39 PM
The handy part is that about the time the oil temp gets to damaging levels, your ass is gonna be uncomfortable enough to be off that bike anyway. It's called self-preservation.
