2013 Fork Oil capacity - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Suspensions
Suspensions Discuss all you Suspension needs and wants here! Sponsored by: JRI Shocks
Old 06-03-2013, 05:15 AM
torqu's Avatar
torqu torqu is offline
Default 2013 Fork Oil capacity
Just wondering what the capacity for each fork is supposed to be . I changed over to black fork legs and I cant get a straight answer. I've been hearing 10.7 or 10.9 does that sound right?
Owns " One of those big wheel baggers" you can't ride
Old 06-04-2013, 11:43 AM
torqu's Avatar
Forget it. I just poured 315ml in it and called it good.
  #3
Old 06-04-2013, 11:50 AM
ironmark's Avatar
ironmark ironmark is offline
10.8 fluid oz or 319 ML per fork tube.
08 FLTR candy red sunglo, 103 Stage II, Woods TW-222 cams, V&H Dresser Duals with Monster Rounds, Thundermax tuner, Willy Shiny Wheels and Forks and a bunch of other stuff.
  #4
Old 06-04-2013, 11:55 AM
rg_dave rg_dave is online now
The number of oz is just an estimate. It's set up to be a little more than you need then you reduce it to the correct level. You add that much oil then use a fork oil height tool to adjust the oil to the exact height in mm. You can guess but your front suspension will perform much better if you get it exact. See the service manual. There is a table and it does a great job of describing the procedure.
http://www.amazon.com/Motion-Pro-08-.../dp/B000GZPCYI
I'm at work right now or I'd give you the amounts.
  #5
Old 06-04-2013, 02:17 PM
NorCal's Avatar
NorCal NorCal is offline
the 2013 Manual states with damper valve:
10.7 oz
317 ML
4.92 IN
125 MM
  #6
Old 06-04-2013, 04:48 PM
torqu's Avatar
Yeah. I just threw in 317 ml and called it good. Handles fine. Picked up a service manual today. Didnt measure like the manual stated. We'll see what happens.
  #7
Old 06-04-2013, 04:50 PM
torqu's Avatar
Dave, thanks for the link for the tool.
  #8
Old 06-04-2013, 06:36 PM
Worst case it would be a little stiff. If you put new lowers on you'll be really close just putting in that amount.
2013 Ultra
Pics here: http://www.roadglide.org/album.php?albumid=2193
  #9
Old 06-04-2013, 09:26 PM
torqu's Avatar
Yes. I put new lowers and replaced all seal even though it only has 800 miles on it.
Insurance
Please select your insurance company (Optional)
