Vance and Hines Dresser Duals - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Intake and Exhaust
Intake and Exhaust Intake and Exhaust Systems for Road Glides
Old 06-20-2013, 10:07 AM
OKBigD's Avatar
OKBigD OKBigD is offline
Default Vance and Hines Dresser Duals
Ok, so I've installed the Vance and Hines headers, Klock Werks mufflers, after my first long ride I noticed a slight squeaking sound coming from the front right. It turns out it is the heat shield rubbing on the inside of the rear floor board bracket. I loosened the heat shield but it's already all the way forward and rotated as far as it will go. Has anyone else had this issue....
Will the floor board relocation kit eliminate this?
Old 06-20-2013, 10:25 AM
reds4's Avatar
reds4 reds4 is offline
First off (can't help it) it's a "foot board", you can always adjust it up.
  #3
Old 06-22-2013, 10:21 PM
CebuRyda CebuRyda is offline
I'm running the V&H Dresser Duals w/Rineharts. I'm not seeing where your rear foot pegs/floorboard will make contact. I have heard of the V&H dresser duals doing this with various combinations. The parts guy at the local HD even had a spacer just for this situation. Can you shoot a photo where it makes contact? For reference, my rear footpegs are at the highest position.
"All I need are big dreams and open highways"
  #4
Old 06-23-2013, 02:22 AM
denis75's Avatar
denis75 denis75 is offline
Did you install the spacers that comes with the exhaust? Had the same problem but on the front bracket. Ended up ordering Harley Goodies foot board extenders. Did however loosen everything up and finally got everything too line up.
2012 Road Glide BIG BLUE PEARL
  #5
Old 06-23-2013, 03:10 AM
denis75's Avatar
Looking at it again and mine was rubbing on the rear bracket as well. Harley Goodies will definitely fix the problem but don't think you should need them but puts you in a more comfortable position anyway.
  #6
Old 07-02-2013, 05:11 PM
OKBigD's Avatar
I loosened up everything again and moved everything as far as I can and i now have 1/8" clearance... Not much but no more squeaking from rubbing... Hopefully I won't have this problem return.....
  #7
Old 07-02-2013, 05:38 PM
1stglide 1stglide is offline
had the same problem went on ebay found 1 inch floor board spacers fixed the problem and i got a more comfortable ride
  #8
Old 07-02-2013, 05:45 PM
by the way arlin ness calls them floor boards .pm calls them floor boards .bagger nation calls them floor boards . and so does harley so i cant help THERE FLOOR BOARDS.
