Battery tender - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Equipment-RG
Old 07-29-2013, 08:38 PM
crossbonesglide's Avatar
crossbonesglide crossbonesglide is offline
Default Battery tender
So after charging all night the light still shows charging. It's never taken that long to charge. The battery isn't a year old yet, I'm thinking the tender may be bad.
Old 07-29-2013, 08:55 PM
Tourhog's Avatar
Tourhog Tourhog is offline
Had same issue once. It turned out to be the pigtail hooked up to the battery was bad. Not the charger or battery.
2013 RGU BBP
  #3
Old 07-29-2013, 08:58 PM
Bull_Duck's Avatar
Bull_Duck Bull_Duck is offline
If the charger lights on, then likely ok. Loo to your battery connection. All the terminal connections + & -, not only trickle charger.
  #4
Old 07-30-2013, 02:42 PM
CSM11's Avatar
CSM11 CSM11 is offline
I agree check connections
  #5
Old 07-30-2013, 03:23 PM
PGR's Avatar
PGR PGR is offline
Depends on which version you have. I have the HD version.
Flashing Amber = Disconnected
Solid Amber = Begin charging
Flashing Green = Almost charged
Solid Green = full charge
...................... Ron..........................
  #6
Old 07-30-2013, 03:36 PM
HogPro's Avatar
HogPro HogPro is offline
www.hogpro.com
Some pigtails have fuses in tehm. Check the fuse.
  #7
Old 07-30-2013, 04:13 PM
moose1's Avatar
moose1 moose1 is offline
I had a battery on my 2011 heritage go bad at about 6 months old and it cooked my battery tender
Sent from Motorcycle.com App
2012 FLTRU vivid black
life has no remote
get up and change it yourself
  #8
Old 07-30-2013, 04:17 PM
throttles&triggers's Avatar
throttles&triggers throttles&triggers is offline
Unplug the tender from the outlet or extension cord and plug it right back in. The light should go to green if it is charged, if not something may not be connected properly, most likely at the battery. If your connections are all good, it could be the battery tender.
The other option is that you have a bad regulator and there was a VIN recall on those. That should be looked into, as well. My tender did not indicate a full charge until the regulator was changed out under warranty.
  #9
Old 07-30-2013, 05:10 PM
It is the HD battery tender. It worked last week with no problems. This week solid amber for 12 hours. Pulled the fuse and the amber flashed, replaced the fuse and checked all the connections, all tight. Is there a way to check the voltage with a voltmeter from the tender without killing myself? Don't think the battery is already bad on a 2013 model.
  #10
Old 08-01-2013, 12:36 PM
After giving it a couple more hours yesterday it finally turned green.
