23" or 26" front wheel - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Wheels and Tires
Wheels and Tires Section for Roadglide wheels and tires
Old 08-06-2013, 02:44 PM
bbrunnett bbrunnett is offline
Default 23" or 26" front wheel
im looking into raking my bike, but id like some feed back on it. I looked at arlen ness ko trees. they are gonna give me a 11 deg rake. With that ill be able to run a 23" or 26", but not sure yet. anyone have pros and cons about this. is bigger really better?
Old 08-06-2013, 03:12 PM
HogPro's Avatar
HogPro HogPro is offline
www.hogpro.com
I asked about the Ness trees on chopped baggers and got a big fat NO. That was all I needed to hear. If you are going to chop the neck regardless do a 26" but I think there is a lot more involved in getting a bike with a 26" to look right than a 23". With a 26" I am of the opinion that you need to do extended bags and rear fender at the same time as the elongated and lengthened profile really lends itself to a 26". The same is true for a 23" but it is not as big a deal as the wheel is not quite so massive.
Drew
  #3
Old 08-06-2013, 04:13 PM
Redbeard77's Avatar
Redbeard77 Redbeard77 is offline
From my research, it seems that you can just change trees to run a 23 (Pickards are highly recommended), but have to rake the neck to run a 26. Trees can be swapped back to stock if you ever wanted to, but chopping the neck is a more permanent commitment for what that's worth, not to mention the added expense and it's less of a DIY mod.
I also agree with Drew that you need to go all-in for the 26 to look right, but I'm sure if you're considering the big wheel you've already thought of that.
Happiness is a warm motorcycle.
  #4
Old 08-06-2013, 04:44 PM
HogPro's Avatar
www.hogpro.com
I plan on doing a 23" with the Pickard trees on my ride, just need the parts and money. I'll try and get some pics when doing the mods as time allows. Right now I am waiting on trees and springs from Pickard. I am sure I can find a 23' wheel around here.
  #5
Old 08-06-2013, 06:11 PM
torqu's Avatar
torqu torqu is offline
26. Chop it. 9* trees 9* weld on kit. Only way to go.
Owns " One of those big wheel baggers" you can't ride
Insurance
Please select your insurance company (Optional)
