Using HD trip program - Road Glide Forums
post #1 of 15 (permalink) Old 06-19-2012, 06:59 AM Thread Starter
Will this program sync to my garmin 665?
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
RoadGlide0611 is offline
post #2 of 15 (permalink) Old 06-19-2012, 10:02 AM
It should. I sync my 660 with no problems.
2011 Road Glide Ultra CVO, Slate/Black, Windvest 15, 110 cu in, SEPST, Thunderheader 2 into 1, TMan 555 Torqster cams, 99 hp, 115 torque
Ozoneman is offline
post #3 of 15 (permalink) Old 06-19-2012, 11:29 AM Thread Starter
Cool... Thanks
post #4 of 15 (permalink) Old 06-19-2012, 12:37 PM
I was able to sync with my ZUMO, but the route was broken up into several different routes when imported by ZUMO. Each waypoint is treated like a separate destination and route created for each waypoint instead of one continuous route. Anyone else have this happen?
kbrown82 is offline
post #5 of 15 (permalink) Old 06-19-2012, 01:00 PM
EZMotoTim's Avatar
The short answer, is "Yes." But you know I have a tendency to give longer, more thorough answers.
first, I want to clarify the terms, "Location" and "Waypoint" as used in the Harley Road Planner. A location is created when you r-click on the map and select Add Location or select Add Location on the list at left. When you add a location you enter an address and a numbered, square, call-out is displayed on the map. when you r-click on the map and Add Waypoint, a flag is displayed on the map.
The Ride Planner creates a separate route for each Location-pair. That is from 1-2, 2-3, etc. The way points are included in the route as via points. Each Location is included in the route as via point and as a waypoint tag. The routes end up on the GPS under the Routes button. The waypoints end up under the Favorites button.
What I do is do a Manual export of the data to a gpx file, then edit the gpx file with an XML editor before copying it to the GPS. If you are interested, I can explain editing the gpx file.
2017 FLTRXS, Givi V56 Topcase, Windvest 10", National Cycle Hand Deflectors, Rapid Transit Tank Bag. My last bike was 2014 Triumph Trophy SE. Before that: 2010 FLTRX.
EZMotoTim is offline
post #6 of 15 (permalink) Old 06-19-2012, 01:40 PM
bvanlente's Avatar
I'd like to know. Please explain.
Men fight for freedom, then they begin to accumulate laws to take it away from themselves. ~Author Unknown
bvanlente is offline
post #7 of 15 (permalink) Old 06-19-2012, 01:43 PM
08Zinc's Avatar
+1 on explaining the .gpx editing
Blessings, Zinc -
08Zinc is offline
post #8 of 15 (permalink) Old 06-19-2012, 01:59 PM
Shrug's Avatar
Send a message via Yahoo to Shrug
Make that three!
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #9 of 15 (permalink) Old 06-19-2012, 02:13 PM
PGR
PGR's Avatar
You should have a START [1] and an END [2] anything in between should be a WAYPOINT.
Here's how I do it. If you want to ride certain roads, create a whole bunch of LOCATIONS along the way until you get to your destination. Once you have the route fine tuned, RIGHT CLICK on the LOCATIONS in between the start and end, one at a time starting with [2] and change them to WAYPOINTS.
The waypoints (the more the merrier) prevent the GPS from routing you the way it thinks is the best.
I have a route from Western Illinois to Rapid City South Dakota, that uses 7 roads..... and has 47 waypoints. That keeps the GPS from wanting to use roads that I don't want to use..
I like SD44 and my GPS likes I90.... so the waypoints keep me on SD44 and the nice scenery and away from the interstate in South Dakota. It allows my to pick and choose the interstates that I DO want to use, without turning them off in the settings.
If your route is a multi-day trip, at the end of the day, DO NOT hit STOP. Just let the GPS power down when you stop for the night (or breaks, including meals) .... When you fire the bike back up, the GPS knows it's still on the route, and just takes up where it left off.
I did 3900 miles in a 5 state loop last summer this way, and the GPS never missed a turn.
Ron..........................
PGR is offline
post #10 of 15 (permalink) Old 06-19-2012, 02:15 PM
Yes, the overall plan is broken up in to separate plans, but not by way-points, but by destination (the numbered locations that you enter when making the plan). The file names are the name of the overall plan with a 1, 2, 3, etc. at the end of the plan name. What I do is bring up each individual plan on the GPS before taking the trip and rename each, so I know which plan is for which part of the trip by its new name.
Ozoneman is offline
HD custom seat program ACESnEIGHTS Seating: seats, backrests 5 07-29-2015 08:59 PM
HD Leasing program? Dmize *General Road Glide Discussions/Pictures 15 07-31-2012 08:04 PM
Harley announces factory customization program CHAINSAW *General Road Glide Discussions/Pictures 54 03-04-2011 09:43 PM
**** road glide flag program **** HUTMO *General Road Glide Discussions/Pictures 100 01-14-2011 05:33 PM
Best Mapping Program for MAC stewarrd *General Road Glide Discussions/Pictures 2 11-28-2010 09:36 AM
