Front Brake Pad Prep - Road Glide Forums
post #1 of 9 (permalink) Old 01-16-2014, 07:56 PM Thread Starter
bikepsych's Avatar
Greetings one and all.
Replacing my front brake pads. They're darn near to the plate.
So when replacing the pads with stock ones, do you need to chamfer the edges of the friction materials to reduce chatter? Or similarly do you need to put anything between the pad and piston to reduce chatter? Back in the day the chamferring would reduce squeal.
BG
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
post #2 of 9 (permalink) Old 01-16-2014, 08:05 PM
HellInABucket's Avatar
I just replace the pads straight up.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #3 of 9 (permalink) Old 01-16-2014, 08:11 PM
zemo1017's Avatar
Never done anything other than take 'em out and put 'em back in.
zemo1017 is offline
post #4 of 9 (permalink) Old 01-16-2014, 08:14 PM
No, straight forward just do, the calibers are tricky to clear fender, don't lossen what doesn't need to be! place towels @ tank & @ m cyclinder, fill back to 1/8 from top on lean
reds4 is offline
post #5 of 9 (permalink) Old 01-16-2014, 11:08 PM
I put a little bit of disc brake lube on the back of the pads.
post #6 of 9 (permalink) Old 01-16-2014, 11:32 PM
+1. That can be purchased at any auto parts store. Actually put some on any metal to metal surface but DO NOT get any on the rotor.
post #7 of 9 (permalink) Old 01-17-2014, 09:23 AM
I Never put any disc brakes on with out using brake quiet on the rear.
Big_gary is online now
post #8 of 9 (permalink) Old 01-17-2014, 09:52 AM
I like to use brake kleen on the brake pistons before putting in new pads. Here is a good resource.
http://www.lyndallbrakes.com/service-tech/
HogPro is offline
post #9 of 9 (permalink) Old 01-20-2014, 09:33 PM
Good little read HogPro, chance to say the OM is slightly different, the MC cover should be lossened and tank/fender covered....and I aways hang the front caliber or (s) with wire (frees up a beer hand), use the old pad the clamp against and so on.....the Golds always have extra mils of paint on the back which puts you to the test but the best!
reds4 is offline
Dealer prep charges gkbailey78 *General Road Glide Discussions/Pictures 16 01-16-2013 08:06 PM
Short test trip prep for Daytona ride Chicago Harley Boy *General Road Glide Discussions/Pictures 11 11-27-2012 08:04 AM
Dyno Prep Radioactive *General Road Glide Discussions/Pictures 1 08-26-2012 08:01 PM
Pomfret prep Roadgliders MYFLTRX Road Trip Discussions/Stories/Pictures 25 04-16-2012 07:00 PM
How to prep Speaker Lids for paint? Norie1 Paint & Bodywork Section 5 03-17-2012 02:06 AM
