Need some help with codes - Road Glide Forums
post #1 of 6 (permalink) Old 09-20-2011, 09:25 PM Thread Starter
strangeglass's Avatar
Hi guys
I installed some 12" apes and lost cruise and mode sel switches. No engine light so ran diag. check, no codes. So pull everything apart to look at wires everything looks good. So put all back together turn on switch check all buttons, mode button works. I think all may be good start the bike engine light...... run the diag. Have these codes P1510, p2127, p2138 tried to clear them no good. Back into the wires I go. Think I messed up the little green plug. Any thoughts.
Thanks
2011 Merlot Sunglo RGU, +2 KW sweepers, Avon grips, Rush slip-on mufflers, Progressive 940's.
strangeglass is offline
post #2 of 6 (permalink) Old 09-20-2011, 09:36 PM
Redfish-Joe's Avatar
P1510 Throttle actuator control limited performance
P2127 Twistgrip position sensor 2 low/open
P2138 Twistgrip position sensor correlation error
All Throttle by wire issues. There is a service bulletin for "micro motion" contact wear or fretting that pertains to these issues.
These could relate to your damaged plug.
Redfish-Joe is offline
post #3 of 6 (permalink) Old 09-20-2011, 09:49 PM Thread Starter
Thanks for the reply
So do you think I will need to replace the throttle sleeve or can I cut the wires and get ride of the little plug?
post #4 of 6 (permalink) Old 09-20-2011, 09:57 PM
I don't think I would cut the wires. The Throttle is a rheostat that basically sends a reading in ohms to the ECM. I would think all the connectors work together as a unit. Cutting and splicing could change the ohmic output to the ECM.
post #5 of 6 (permalink) Old 09-20-2011, 11:58 PM
skipperfltr's Avatar
JMO but I dont think an inch or less will change the resistance.....Sotter'em up and shrink wrap'em
50 States on a bike at age 50.
skipperfltr is offline
post #6 of 6 (permalink) Old 09-21-2011, 09:13 PM
Howardsternspenis's Avatar
Question Skipper FLTR
Sotter, really?
HSP
Howardsternspenis is offline
Found some Standox paint codes canukHD Paint & Bodywork Section 1 03-24-2018 10:40 AM
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-03-2017 12:51 AM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 01:56 PM
Engine codes Help? getrdone Troubleshooting for Road Glides 7 09-29-2013 06:01 PM
Help please stalls no codes creed Troubleshooting for Road Glides 5 07-22-2012 09:08 PM
